Pricklely Peete
Franken modder
- Feb 17, 2008
Is the insert spinning inside the knob body ? If so you need to glue the plastic insert inside the knob so it's all one piece again allowing the knob to turn the pot shaft.
Check that and get back to me....if it does spin freely (meaning the adhesive has failed) use super glue to attach the insert to the knob once again.
Let it dry for a while (5 minutes) before putting the knob back on to try it. Do not glue the insert to the shaft.
Report back ASAP please with your findings and I'll walk you through the repair...(it's easy).
Peete.
Peete.
