The 6SN7 Identification Guide
Sep 22, 2020 at 7:13 AM Post #286 of 536
Just received 4 of these General Electric Canada 6SN7GT, any insight onto their history, what the gray collar may be for and date? Has date code H3 as far as I can see.
Sep 22, 2020 at 10:04 AM Post #287 of 536
Those might be Sylvania, and the collar could be a remedy for a loose base.
Sep 22, 2020 at 10:29 AM Post #288 of 536
Construction does look almost identical to a couple Sylvania VT231 I can see, just the bottom getter is different (rectangular open getter). Did Sylvania operate factories in Canada? Wonder if anything else would narrow down the date ranges.
Sep 22, 2020 at 10:45 AM Post #289 of 536
Then probably CBS-Hytron . Not sure if Sylvania ever did have factory in Canada, but a lot of tubes did get outsourced to Canada. Marconi is one company that comes to mind that had almost all their tubes outsourced.
Sep 22, 2020 at 10:57 AM Post #290 of 536
Hi,
I have here two tubes that looks like Sylvania but, unfortunately, do not have any name anywhere... here are some pictures, is there anybody that could help me in recognize them? Do thanks in advance
Sep 26, 2020 at 8:53 AM Post #292 of 536
Here's a riddle for everyone!
Haven't found a picture online of a second specimen, that's why it's here for you!
I'm a warm sounding European SN7 and I lack controlled heater warm-up.
What am I?
Sep 26, 2020 at 10:00 AM Post #293 of 536
What am I?
Hmmm...perhaps a Brimar 6SN7GTY?
Sep 26, 2020 at 12:11 PM Post #295 of 536
What am I?
You'll have to send that to me for further evaluation, Brimar?
Sep 27, 2020 at 8:10 AM Post #296 of 536
Thanks for playing along guys, much appreciated! No one's close.
Another set of hints. This is the current setup (don't do OPT rolling, hugely impractical as can be seen).
The output tubes will teach you the heater voltage. The code seen, the Island of origin. The before told hints the actual brand.
The actual factory was owned by different "companies" over the years. In the early '50s this company (and it's parent company) took over and produced this tube (apparently).
Sep 27, 2020 at 8:34 AM Post #297 of 536
And this is a 6sn7 tube correct? Nice amp, custom?
Sep 27, 2020 at 9:22 PM Post #298 of 536
Sep 27, 2020 at 9:45 PM Post #299 of 536
Sep 27, 2020 at 10:30 PM Post #300 of 536
Not sure what the mystery tube is, but while it does look similar to a Brimar, I'm going to go with it not being Brimar. Top mica is just not what I'm used to seeing on a Brimar 6SN7GT/Y or CV1988.
