Matias
@lovethatmusic Also consider Tanchjim Space as an excellent dual 43131 dongle with both 4.4 and 3.5 mm outputs.
Ok, good to know. I will look into this one also. Thank you!@lovethatmusic Also consider Tanchjim Space as an excellent dual 43131 dongle with both 4.4 and 3.5 mm outputs.
Thanks for your suggestion for getting the 3.5 version of the Dawn. I would love to go with the 3.5 just to avoid having to upgrade my cables.No problem. I'm glad I could help. BTW, Moondrop also makes a 3.5mm version of the Dawn that still uses the dual CS43131 configuration so if you don't want to convert all your cables over to 4.4mm balanced stuff that might be a good way to go. I'm not sure how its specs differ, if at all, from the 4.4mm as I haven't tried it, but people seem to think it sounds essentially identical from what I've read.
Thanks for your suggestion for getting the 3.5 version of the Dawn. I would love to go with the 3.5 just to avoid having to upgrade my cables. That said, I’m seeing the Dawn as a potential endgame portable DAC, so I’d like to feel pretty confident that the 3.5 sounds as good as the 4.4, but I haven’t been able to find any reviews directly comparing the two models. Can you tell me where you read that they are more or less identical?
So kind of you. That’s clarifying - there are very subtle differences. Thanks again for your help, I really appreciate it!Honestly, I'm not sure. Injust remember reading that shortly after the 3.5mm version came out. See, when the 4.4mm version was the only one available the biggest criticism of it was that folks who don't use balanced cables couldn't use the Dawn.
Predictably, Moondrop's answer was to release a 3.5mm version that still utilized the dual chip design. When that was announced, but before it came out the big question was whether they would actually manage to makenit sound the same or would it lose stage, dynamics, and other technical abilities in the move from balanced to single ended. So when people finally started getting it I just remember seeing people mention in posts that it sounded very much the same and was a viable alternative for folks that wanted the Dawn sound/performance in a single ended configuration.
When I get a chance I'll do some looking around in the threads I was frequenting at the time and see what I can find. I'll let you know if anything relevant turns up.
Edit: A quick Google search turned up this quote from the link below.
https://blog.ear-phone-review.com/entry/news/Moondrop_Dawn_1
"The only difference you will notice with the brand new DAWN 3.5mm will be the headphone output port that is now a single-ended 3.5mm instead of the 4.4mm of the OG Dawn DAC/AMP. It is going to be available for 64.99$, 5$ less than its balanced variant."
So kind of you. Thanks! How can this be? Pardon my ignorance, like I’ve said, I’m still a newbie. I was under the impression that 4.4 / balanced is always better. Not necessarily true?
Great perspective and great advice again. Thank you again!No, not necessarily true. Mostly it just depends on how the device was designed. A well designed and implemented single ended circuit can sound just as good as a balanced circuit and better than a poorly designed bakanced circuit. Most devices were designed to run balanced or single ended and if they have an output for the other it's generally just for convinience's sake.
In this case the numbers show that there is lower distortion and increased channel separation on the 4.4mm, but the distortion on the 3.5mm is already outside the audible range and most would say the channel separation difference is also likely beyond audibility. That said, number don't tell the whole story and the only way to know for sure is for you to hear it. All the numbers, advice, and reviews in the world can't replace your ears. However, my bet would be that you'd be happy with either version so if you'd prefer to save a little money and not switch to balanced I think you'd be safe to get the 3.5mm version in this case. However, if you think you may eventually need the extra power available in the 4.4mm version or that you might be looking to upgrade to higher end gear at some point it might be a decent idea to start moving to balanced now.
Only you can decide abd whatever you decide I hope you enjoy your new dongle. Hapoy hunting and happy listening, my friend!
Great advice again. Thank you again!
TempoTec March III M3 can already be ordered and (after applying coupons) costs around 130$.
It features AK4493SEQ, which is nice. The market nowadays is being flooded with ES9038s..
What's your take on this? Does it seem to be a wise investment?
https://www.aliexpress.com/item/1005005324896514.html
Change log:
Add 192kHz support for Amazon music app
add "on/off" switch for Play Store, HiByCast and CoolApk.
Provide a choice for you to run or quit the APP as need.
Save and reserve runtime memory for music process.
Update HiByMusic App to 2.06_V6057
Fix L&R channels occasionally swapped problem while weaken from standby status.
