swanlee
- Nov 21, 2008
I still am of the mind -- hear me Teclast and Nationite -- that this player could be rad, truly rad if: it was small, had buttons, lost the touch screen, and then was given to Rockbox. There are just too many things that are lost on the hardware because of rubbish firmware and the horrid touch interface, a UI that has to be done perfectly otherwise it is rubbish. If Teclast hadn't have jumped the stupid 'me too' bandwagon, this would have been a much better player. And, if the player had gapless and better file system support (ala Rockbox), it would be perfect.
I like the size, I'm not looking for a fuse or a clip and this player is certainly smaller than my old Zune30. I think the size feel and form factor are really fine with this player. No way they could get a battery strong enough to power all the chips in the SFLO:2 in a small form factor even if you removed the screen.The battery they use takes up all of the player inside length wise.
Rockbox will not be possible on a player using rockchip because they have the SDK under lock and key and seem to make everyone that uses a rockchip in there players sign there life away if that sdk gets leaked. So you can blame rockchip on that.
Also the custom UI's that people have created for this are really good, mp4nation has some threads on it they really improve the feel and look of the player. The only real outstanding issue is the lack of proper ID tag support but browsing by directory pretty much fixes that.
