Graph of the Oxygen via a IEC711 compliant coupler. 8/9 kHz area is a coupler artefact peak.
The Oxygen is actually a very technical single DD midFI set. It won't beat some midFI multi BA/hybrid sets in technicalities (micro-details, imaging, clarity, instrument separation), but it does beat most of the other midFI single DD types in this department (eg BQEYZ Autumn, Moondrop KATO). The Oxygen is my current daily driver cause of the good mix of tonality, timbre and technicalities.
The Oxygen can be bright on some tracks at the upper midrange/lower treble, but this can be mitigated to some extent via eartips (eg foams, Final E black tips etc) or via a warmer source. Note weight is a little bit on the lighter side but this aids transients.
Measurements above 10 kHz are not too accurate, but the Oxygen is one of the rarer single DDs to have good upper treble extension (which is usually an area of weakness for single DD sets).
I know the Tripowin Olina is on a massive hype-train on Facebook and social media, purportedly it graphs similarly and uses the same driver as the Oxygen. Well the same driver claim needs to be verified independently, but even if so, the housing and resonances are different between the 2 IEMs (probably the damping too), which can affect the sound. Even if 2 graphs look the same, graphs don't tell the full story. There are some components such as timbral accuracy, imaging, micro-details, instrument separation that cannot be gleaned from a standard FR graph.
Case in point: KZ ZSN Pro X and the TOTL Final Audio A8000 graph similarly but sound miles apart.
