redrol
I see the graph for them and it looks pretty darn good overall. I think it would be a safe buy. I'd prefer a bit more subbass since for TWS you are probably out and about and a bit of extra bass generally helps.
Looks like it was only released 5~8 days so I doubt anyone that has bought has gotten them yet.Just came across the new Echo TWS on the Shenzhen Audio site. Haven't seen any impressions anywhere, but curious. Anyone had the chance to try these?
https://shenzhenaudio.com/products/...ended-diaphragm-dynamic-driver-in-ear-earbuds
I don't know if I understand your bolded portion. Do you want an improvement in technical performance? If so, what parameters. I have yet to see/watch a review that says the Oxygen is a major step up from the OG Hana or Hana 2021 in any parameter, outside of less bling. All the reviews I have seen/watched say that the Oxygen might be a slight step up from the Hana 2021 or Oxygen-filter modded OG Hana.Is upgrading from Hana 2021 to Oxygen worth? i need little upgrade on technicality performance
Depending on your source and unit, it seems pretty much 1:1.
