BenF
- Jan 22, 2013
Gotta love this feedback...
You would be able to use the Coax/Optical inputs of your D2 instead of USB.
The question is - is the 60Hz noise limited to USB or not?
Even if it's not audible under 9 o'clock, it's probably still distorting the sound. You need a new DAC.The noise is always there, connected to any input or not. But it starts become audible when the volume knob reaches 9 o'clock and up, and at 9 o'clock the sound coming out from the headphone is very very loud. So in normal volume the noise is inaudible, at least according to my 'regular' ears. Still, it would be much better if there is no noise at all.
That's pure brain burn-in. Pro 82 doesn't change (thank god!), your brain gets adjusted to the new clear sound.About the Pro 82, after several days it sounds much better. The bass is more present and I don't need to open the bass port anymore. The somewhat harsh treble is also smoother.
NX4 DSD is using OPA2140+OPA1652+OPA1688, so there is a good chance the amp will be usable.I hope it'll be on the HA-2 level as a DAC, mobile Sabre chips are quite easy to implement.
However, if the amp is no good, I'll probably skip it, and wait for a better DAC/Amp based on 9038Q2M.
You must be psychic! Quick - who will win the Superbowl?After going through the forum, I'm definitely intrigued by the 82's. I have a couple questions that I haven't seen covered yet though. I'm stuck between getting the 82's and a new DAC/amp, the m40x's with new earpads (I have brain waves, but zeos swears by the zmf's for them), or the B8's with a new DAC/ amp. I'm coming from the Sony WH-1000xm2's which didn't wow me with sound quality and were painful to have on for more than an hour. I'm assuming your recommendation will be the 82's
Don't have M40x, but here is B8:... but I want to know how all three of these compare with each other.
Pro 82 definitely wins in comfort over B8, the desired sound signature can be attributed to both Pro 82 and B8, the question is - do you want it to sound dead neutral or slightly mid-forward?Biggest thing is comfort, I want these for long listening sessions at work. I'm also looking for a clear/ detailed headphone that is closed with good soundstage (at least as good as closed cans go). I prefer a more flat sound signature, although I like boosted bass with some genres of music.
I had the Chord Mojo and recently bought the HA-2.NX4 DSD is using OPA2140+OPA1652+OPA1688, so there is a good chance the amp will be usable.
You probably rank in the top 1% of people who don't need a new DAC at the moment.I had the Chord Mojo and recently bought the HA-2.
Don't do this to me please!!
Absolutely, and I know it. But, NX4 DSD's design looks amazing!!You probably rank in the top 1% of people who don't need a new DAC at the moment.
Didn't Oppo do something with the amp stage of the HA-2SE taking explicit advantange of some new components in the ES9028-Q2M chipset? I think I read somewhere about it, if I recall correctly, that the ES9018-K2M chipset was very different in that respect.As for the amp part, it will be even harder for NX4 DSD to match HA-2's performance.
Even Oppo themselves failed with HA-2SE to do so.
If you finally get it, please let us know.I doubt it can exceed HA-2 level of performance both as a DAC and as an AMP.
Congratulations!Santa came to town, boys and girls. And he didn't disappoint!
Please do and let us know!Now I want to test them side by side, to see if I can spot any significant differences, just out of curiosity
I knew it, this will be a never ending journey once the path is taken...New headphones, new cable, new DAC, new this new that...Even if it's not audible under 9 o'clock, it's probably still distorting the sound. You need a new DAC.
Sure!Please do and let us know!
A PCM2704 DAC/amp for 35$? You can have a DAC for 9$: https://www.head-fi.org/threads/tak...iscussion-thread.849965/page-37#post-13909670...What do you think about Topping NX2? I can stretch my budged for it.
