Miiksu
- Aug 28, 2013
Medium to high volume. It's not that bad when lower volumes. Mostly its the canny sound I don't like. My modded HF580 has still that ringing but eliminates almost 100% the floppy and tinny sound and lowers ringing. Maybe some easy inside back dampering is enough. But I haven't tested any easy internal mods yet. All was external. And I recommend tape the front and back with masking tape or washi tape if not going to do any other mods.Thank you for the elaboration, will this be heard with normal listening or only with a serious critical listening? my cans back ground is HD650, H4xx and Fostex T50RP mk3
