Frabera
Same problem when connected wireless with an iPhone the result is a bit disappointed, it seems the firmware has not been well suited for the iPhone…
That is correct regarding Solitaire T switched on, but no Bluetooth.Because this thread was important source of information about S-T for me, I think it would be useful to leave my conversation with T+A support here.
Q: I frequently prefer usb-c connection + bluetooth off (USB-C DAC?) mode over passive mode (via 3.5mm) for Solitaire T headphones with my Macbook Pro M1 2021 for listening to music. Is a permanent connection to power safe for the headphone's battery? Is there any battery protection for this use?
A: The Solitaire T is designed for continuous operation on a supply voltage. The battery is monitored and protected by an intelligent battery management system.
Could it be that you came from the original factory shipped firmware and that you skipped a few by going immediately to the last one?With the new updated firmware the SQ is getting better with wireless HQ mode using my iPhone 13 as a source, so happy !
,WDitters could you advise on an upgrade balanced cable which may increase sub bass as well as soundstage and keeping details..,
Lets say I have the phones paired to 3 different devices, I'm usually having either the Phone+Desktop or Phone+Laptop turned on, very rarely is all my 3 devices turned on.
Will I be able to listen effortlessly on my 3 devices, given that I don't have them all turned on at the same time?
No. Even if you have 3 or more devices paired to the ST and BT on in all devices, the ST will connecting only to last 2 devices automatically.
If you want using other third device, you must disconnecting one of the 2 paired devices with ST and then connect a new ‘second’ device. I know because I testing this before with 3 devices. I think this is true with all or the majority of multipoint BT headphones (maybe the only exception is with Apple earphones/headphones, but only if using Apple devices (iPhone, Mac, iPad or Apple TV)).
... which is not specific to the ST but rather behavior by design. Bluetooth Multipoint by design is limited to the 2 last sources the - multipoint compatible - device (headphones, earbuds, TWS earphones etc) was connected to.No. Even if you have 3 or more devices paired to the ST and BT on in all devices, the ST will connecting only to last 2 devices automatically.
A new update for the app in iOS is available (1.0.4). The notes saying:
- Bluetooth connection issues fixed.
- Improved Bluetooth pairing.
Unfortunately I don’t have my ST with me now because I’m away some days, so I don’t know if the ST having a firmware update too. Maybe others persons can checking this?
