Hey all,
I have a small problem with my ST‘s. At the right side there are two scratch marks on the aluminum frame. Those marks come definitely when I rotate the right earpiece at some point, because the upper frame ist touching the frame below at one point. There is kinda more moving space between the upper frame and the one which holds the right earpiece.
On the left side everything ist perfect. Sometimes I can feel at one point when the frames are touching when I am rotating the earpiece, but nothing on the left side.
Would you write a complain or suggest for a solution?
The left side has no scratches and I am definitely not using the headphones wrong or something.
Just asking myself if I am too picky, but on the other side it is a 1300 ,-€ product.
Thank you for your thoughts.
