Here are a few examples of the differences..
Topaz:
Size
75mm(W)*30mm(H)*126mm(D)
Spec
1) Main DAC : BURR-BROWN PCM1792
- 24 Bit 192 KHz Sampling Advanced-Segment Audio
Stereo DAC
- Dynamic Range : 123 dB / THD+N : 0.0005%
2) Digital Controller : Cirrus Logic CS8416
- 32KHzto 192Khz Sample frequency range
- Low Jitter Clock Recovery
3) USB Controller : BURR-BROWN PCM2707
- Full speed transceiver (Real Audio 1.1)
- 32Khz ~ 48Khz / 16bit delta-sigma stereo
4) OPAMP : TOTAL 8 pcs (DIP type)
- Output : Analog Device AD817 x 2 pcs
- I/V : Texas Instruments NE5534 x 4 pcs
- Headphone : Burr-Brown OPA2134 x 2 pcs
5) TCXO : 1.0ppm
6) Output level : 2Vrms
7) 1 x 5.5mm Gold-coated Stereo Headphone Jack
8) 2 x selector (Power & Output selection)
9) 1 x Volume controller & 1 x topaz color power LED
10) Gold-coated RCA jack (Left / Right)
11) DC 6V In
12) USB and Optical input
Features
2) USB & OPTICAL input
3) HEXAD type OPAMP : Dual mono design
- Right 3 OPAMP / LEFT 3 OPAMP
4) Sanyo OS-CON / Wima / Vishay Dale, Siver Mica
5) 24bit, 192KHz support
6) Output level 2V: 24 ~ 300 ohm headphones welcome
7) 4 block isolated design (Input, Digital convert, Main
Power, Analog)
8) Plug & Play, no installing drivers or software.
9) Full Aluminum anodizing case, high quality brass metal
foot and aluminum volume knob.
10) Recommended break in time : 150 hours
11) 0) MS Windows 2000, XP, VISTA and Mac
Included Accessories
1 x USB cable / 1 x User’s manual / DC 6V power adapter
Emerald:
Size
Spec :
1) DA converter : TI PCM1793, 24bit / 192Khz
2) USB controller : TI PCM2707, full speed
3) 24-Bit Delta-Sigma Stereo DAC
4) TCXO : 1.5PPM
5) 3 OP AMP : TI opa2134 / opa2604
7) Dynamic range : 113 dB, THD+N : 0.001%
8) 1 x 5.5mm Gold-coated Stereo Headphone Jack
9) 2 x selector (Power & Output selection)
10) 1 x Volume controller & 1 x Green color power LED
11) Gold-coated RCA jack (Left / Right)
12) DC 5V In, DC5V &
13) USB In
14) Brass metal foot – anti-shock & anti-vibration
Features :
1) 24bit, 192KHz support
2) Out sound level is 2Vrms (same level as Hi Fi CD
players), so it can accept upto 300 ohm Hi Fi headphone.
3) MKP level of WIMA’s coupling condenser, Resistors from
Vishay Dale, Silver Mica, etc., which can present very high
performance.
4) ‘TCXO’ 1.5ppm which is normally using by the very highend
audio product and DAC.
5) Three opa AMP system
6) 4 different block design (Input/Digital convert, Main
Power/Analog)
7) Power level filtering function
8) USB power in or DC5V power adapter. User can select to
USB power-in or separate DC5V power-in.
9) Plug & Play without installing drivers or software.
10) MS Windows 2000 professional, XP and VISTA and Mac
OS (Mac OS’tm’9.1 or later Japanese/English edition, Mac
OS X 10.0 or later English edition, Mac OS X 10.1 or later
Japanese edition SP)
11) Full Aluminum anodizing case & high quality Brassmetal
foot, which can reduce any kind of external noise and
resonance as much as possible.
12) User’s easily select output-channels using this selector.
13) Gold-coated RCA output can be connected to Hi-Fi
integrated AMP.
14) Small size & Portability : it is easily to take out with the
notebook out side.
15) Aluminum volume knob.
1 x USB cable
1 x User’s manual
DC 5V power adapter
The Topaz added the Optical input.
