I as mentioned before you should look for older Stax amp used, like SRM-1MK2 PRO or maybe SRM-T1. They are good for the money and to my ears SRM-1 sounds better than all but TOTL new Stax amps. It is capable of driving whatever you plug in as it as it's max output voltage is 370V. Drives even SR-007 and Sigma fairly well in my opinion. You need to use a good source or even better a pre-amp before it, makes all the difference.
WooAudio sells the SR-202 separately for 350USD, but of course they do not sell the SRM-252. It's only a hundred or so cheaper than buying the SRS-2050 system .
The SR-202s are a nice headphone and, from my experience, they sound much better out of my SRM-007t compared to the SRM-252II.
The SRM-007t is a very nice Lambda amp, it works great with the SR-Lambda Pro. I find the SR-007 unoffending but at the same time a bit dull with the lesser amps.
X2. One could really stop right here, even with a T1S (what I'm using right now). Indeed, I am tempted to do just this. DAC notwithstanding, to best such a rig either requires serious DIY or horrendous expense.
