Starving Student Millett Hybrid PCB Step-By-Step Build Guide
post-6044176
Post #31 of 81
T.IIZUKA
I arranged parts. I finished producing.
The voltage necessary for the vacuum tube did not go out, and the sound was not emitted.
The pattern was chased, and parts were checked.
The AC adaptor is not CISCO. No be known probably because of that.
CISCO's adaptor is obtained now.
post-6045036
Post #32 of 81
Sparhawk
Here are the pics of the finished unit:
Starving Student Millet Hybrid:
Thanks again to tomb and everyone else who has had a hand in making this such an awesome/easy build.
post-6048364
Post #33 of 81
T.IIZUKA
Obtaining the case and Japan's heat sink is difficult.
The stopping and case are being produced using alternative parts such as TAKACHI.
It worries about whether it goes well because it is CISCO 48V200mA though the AC adaptor was ordered yesterday.
Do 10kΩ and A curve Pot (LOG)?
As for the ALPHA product, because obtaining is difficult, substitution Pot is scheduled to be used.
It is expensive though can easily obtain if Diji-Key is used when thinking about the exchange rate.
post-6050143
Post #35 of 81
T.IIZUKA
Originally Posted by dsavitsk /img/forum/go_quote.gif
200mA is too small. You need at least 350mA.
OK Thanks,
When it is Japan, it is hard-to-find.
post-6050384
Post #37 of 81
tomb
Member of the Trade: Beezar.com
Originally Posted by smeggy /img/forum/go_quote.gif
Great job Tom, one of these days I'll get my pcb done and running... one day
Thanks, Smeggy - I'm sure it'll look awesome when you do ... like the rest of your work.
post-6106746
Post #38 of 81
TwoTrack
Atlanta
Atlanta
Website
www.cnet.com
Just found this thread, amazing work Tom.
post-6124145
Post #39 of 81
ntrl
Great work. Perfect tutorial for beginners DIYers
Thanks.
post-6135580
Post #40 of 81
Gilly
excellent guide and by the sounds of peoples opinions its a good little amp too
I would be very interested in building one in the future, thank you for the guide!
oh yeah, and +1 for the B22 guide
post-6173451
Post #41 of 81
PianistOne111
I find that an easier way to separate the two parts of the tube socket is to drill from the bottom slightly off-center. This should weaken the flange on the bottom part of the pin, which you can then easily tear off with pliers.
post-6176422
Post #42 of 81
choka
I spent the whole night tonight trying to separate the socket without a drill because i don't have one, and I broke two of them already, and a screw driver. The socket is just unbelievably brittle.
post-6176499
Post #43 of 81
tomb
Yep - sorry to hear it, but that's why I drill mine. Some people are able to do the screwdriver thing without a problem. I don't know how, though.
post-6177594
Post #44 of 81
Juaquin
Maybe you just sent me two really good sockets
I started with a spudger (plastic tool used for opening electronics cases without damaging them) and switched to a small flat head once they were opened up a bit. I definitely don't recommend trying it this way (as apparently very few people have had success) but if you're desperate I can confirm that it's possible.
post-6177777
Post #45 of 81
choka
May be the ones I've received are different. The whole socket cracked after I try to pry them apart.
And the ridiculous thing is, after the socket has cracked, I am left with just the pin. I hold the two sides of the pin with two pliers and try to pull them apart. They just refuse to separate... I am not a super strong muscular guy but I am still almost 6-2 and not THAT weak...
I don't know what to do now. I broke two and I still have two left. I feel unethical to "borrow" a drill for one time use for this, but on the other hand I don't think I have a choice, since Tom doesn't have the time to drill it for me before he sent it out because he has such a lot of order to handle.
