onocentaur
- Jan 13, 2007
I'll think about it tonight. Right now I'm too eager to pull the trigger, it does look utterly wonderful though
![very_evil_smiley.gif](http://www.head-fi.org/forums/images/smilies/very_evil_smiley.gif)
Originally Posted by cosmopragma /img/forum/go_quote.gif Unfortunately my favorite headphones are electrostats so no really reasonable way to benefit from this excellent technology. |
Originally Posted by mopps /img/forum/go_quote.gif Cosmo, you can benefit if you exercise yourself in patience and wait a little for the hifi model. ![]() |
Originally Posted by bizkid /img/forum/go_quote.gif I'm in contact with SPL for some time now, all the info i could get... |
Originally Posted by Cecala /img/forum/go_quote.gif What is the weight of the unit and how solid is the amp overall? Thanks |
Originally Posted by fkclo /img/forum/go_quote.gif You can download the user manual for SPL website. The dimensions of the Phonitor are : 106 x 216 x 393 mm (H x W x D) without the feet, height is 88mm Weight is 4.05 kg. I used XLR connectors for input - either balanced or not. Hope this helps. F. Lo |
Originally Posted by cosmopragma /img/forum/go_quote.gif I've heard rumours before there will be a stripped down (and less expensive) consumer model but no details at all. Do you happen to have some insider knowledge or are you just speculating? |
Originally Posted by fkclo /img/forum/go_quote.gif If a hi-fi version means a stripped down model with less features I would think the Phonitor will have less fun, even if the sonics are the same. There are quite a number of "monitor" class headphone amps on the market, but the unique thing about the Phonitor is its special cross-feed and speaker simulation features that make itself into a different class. For good quality solid state amps, we do have a lot of choices already. F. Lo |
Originally Posted by Cecala /img/forum/go_quote.gif Bizkid, can you elaborate on the fit and finish of this amp. The volume knob appears to be made of plastic, is it not, and how damp is the action here? What is the weight of the unit and how solid is the amp overall? Thanks |
Originally Posted by bizkid /img/forum/go_quote.gif Fit and finish is the same as with all other SPL gear. There are no plastic parts on the frontpanel, all knobs are made out of metal. The only plastic parts are the feets afaik. The volume knob moves very smooth. If you have a studio equipment dealer near you you can check out the other SPL gear, they are all build very similar. |
