eldss
- Feb 5, 2015
Could anyone advise on the sizing comparison between the single vs dual flange Spinfits? I use the small singles and would like to try the duals. Thanks!
My pleasure, @eldss!Thanks for the links Maurice!
I will, ordered yesterday and will report once it get them.Hi eldss, if the small duals work for you, could you post your thoughts please. I too have small ear canals and I am always looking for views on potential tips.
Thanks in anticipation.
I'll take a gander at what TwinBlade tips fit the SE846 without modification when I get home and I'll take a picture and/or give you the model name(s) as well.so i ordered spinfit cp240 for my ibasso it03, also I saw there is spinfit 200,220,230 what are these variant does any of those fit shure 846
I like spinfit cp240 with my ibasso it03 alot alot, and then I modded my shure 846 with a stem from westone and slid over the cp240 and boom I like alot how shure 846 sounds with cp240 in a modded way.
so was wondering what those other spinfit cps are and would any fit shure 846 without having to do a mod
Try the CP240 series. I listened to the newest series at CanJam SoCal 2017 (the Icarus III is seriously legit), and the CP240 series should fit without issue. The other Double Blade (was called TwinBlade) models are just a tad too narrow of nozzle stalks in my opinion for Trinity's newest IEMs nozzles.I've looked at their compatibility charts but only find Trinity Hyperion and the old Deltas, but no others. Any idea which dual flange units will fit the newer Trinitys?
And, I'm trying to guess which ear-size to get. L triple flange silicones generally work, but sometimes a M or ML double works. Which spinfit do y'all suggest? TIA
Thanks. The Spinfits that came with tithe Sabre just won't fit onto a Master filter. If those are cp100's that's 3.8mm.Try the CP240 series. I listened to the newest series at CanJam SoCal 2017 (the Icarus III is seriously legit), and the CP240 series should fit without issue. The other Double Blade (was called TwinBlade) models are just a tad too narrow of nozzle stalks in my opinion for Trinity's newest IEMs nozzles.
