nekromantik
- Jul 30, 2009
haha!
My ears are fine thanks very much
i received the spinfit cp240 they are really amazing, I will test them more but the first impressions are amazing i used them on my ibasso it03
I wish they have some for shure 846, so i will do a simple mod and slide them over shure 846 to see how they will work on shure 846
@Sound Eq - not able to quote/reply to you via smartphone (with your content on my post/Head-Fi in transition) - even though there are double flange SpinFit tips with narrow nozzles (not the CP240 by default), I feel the fit over the Shure SE846 still isn't as snug as the single flange CP800, which was made specifically for narrow-nozzled IEMs such as the Shure, Westone, Sensaphonics, etcetera IEMs.
Have you tried the CP800 with the SE846? It's one of my favorite sizes-fit-most tip paired with the SE846.
what i will do is take the stem of a westone star tip and then slide over the cp240 and by that they will sit tight on the shure 846, as i have few stems of westone star tips laying aorund. I will report back tomorrow
Cool - I've done that with V-MODA tips and the SE530 stock stem a long time ago, good for the most part but the tips were prone to sliding around, especially when pulling the housing out of the ears (I had a tight fit).
In case you missed it above, have you tried the CP800 tips with the SE846?
I will buy those as well and report back
So I just received some Westone W40's and spent...oh...6 HOURS trying to determine which tips worked best.
All of the included foams attenuate the high frequency too much. The Largest silicon is the only one that fits, but I feel like the vocals get overshadowed by the low end. I have a. Pair of Shure Olive's in Medium, but they are a tiny bit too small...
So I'm thinking about ordering the SP800's in M and L next. I'll go through the thread later...as well as 20 more I'm sure, but for the time being:
Can someone compare their experience with the Spinfits on a W40 vs stock TRUE and STAR?
