ra990
Rear XLR balancedI'm curious if you mean Susvara straight out of the TT2's front SE jack or out of the rear XLR.
Hey guys. Could I get some advice?
I'm using the rockna wavelight as dac/pre to an apollon power amp, to my susvara. It sounds amazing to me as it is right now, but is there any added benefit of adding a dedicated preamplifier to the setup?
Tube pre such as a line magnetic, modwright ls100, atma-sphere mp3. Or solid state like a Holo Audio Serene or musical fidelity m6s pre.
Or is it good enough just to keep on using my dac as a pre?
*edit
I have tried the wa33 as a pre, and also my Audiolab 8300a integrated in pre mode. And I didn't think the sound from either was better than the rockna as dac/pre. The 8300a as pre was actually quite bad.. So wondering if a dedicated pre would be a lot better.
I can also attest that the Wavelight's variable analog output is so good that, one can easily skip a pre-amp.
Oh yeah... the app pairing is just so alpw if it works at allIf only Rockna had added an IR remote.
I want to do something similar with my Scott 299D but I haven't been able to figure out the best resistor set(s) for all my headphones.Just playing with my Van Alstine Ultravalve from my 2 ch stereo setup...
Dont try this at home!!
LOL
https://diyaudioheaven.wordpress.com/tutorials/power-amp-adapter/I want to do something similar with my Scott 299D but I haven't been able to figure out the best resistor set(s) for all my headphones.
I admit, I have never fully understood this.
Does this apply to all power amps?
Eg if I'm using a purifi class D power amp rated 227w into 8ohm, for a susvara, I'm out of the graph and in red zone. Based on the graph and explanation, do I have to use a resistor or just be very careful with the volume control?
You can run any headphone off any amp. Just do a quick db to Watts calculation (every 3db is half the power) to figure out where you need to be power-wise and use the below link. So if you do 12db attenuation you'll be feeding ~14 watts to the Susvara. 15db would be 7 watts. You're wasting massive amounts of power through the resistors though. Better get like...100W resistors.
https://robrobinette.com/HeadphoneResistorNetworkCalculator.htm
B.Ok so I've tried reading through both webpages (several times). My knowledge on electronics is elementary at best. I know a few folks on TC and Susvara not using any resistors. Could u dumb it down for me?
A) Not safe for me to proceed as I am doing now (power amp, speaker taps adaptor, no resistor, susvara).
B) OK to proceed as I am now, but be careful of volume control.
B.
If you don't exceed the max power for the headphone you are fine. A 500 watt amp can do 5 watts if the input signal level is controlled and/or the volume/gain is used properly. IMHO. I have used a Hafler DH500 (true 300 watts into 8 ohms) to drive my HE1000 and HE6 direct from the speaker terminals. Keeping the preamp volume at reasonable levels I could maintain 80 to 85 DB no sweat. I would never open the thing up, but I am sure my ears would quit before the headphones if I had ever had tried.
The chart only shows what happens at max output for a given amp... Amps are seldom run at their max power levels. Neither do you want to... but then you are in control of that. In my experience, any kind of resistor network (and I tried several different networks and types of resistors) reduces sound quality.
I never accidentally bumped a volume control ever.The problem is that one time you accidentally bump the volume control. Poof
