One of the loaner pieces we received for the meet was the Luxman P-200 which is the little brother to the LUXMAN high-end series P-1 and will be retailing for $1500 when it hits the US. I got to spend a couple of days with it after the show so I thought I would share my opinions about it.
It is well priced within the competition. I first found out about the P-200 while at CES. Jude introduced me to Philip O'Hanlon, who is the US importer at On A Higher Note. Jude owns the Big brother and has raved about it so I requested that we have the new unit at the Charlotte CanJam to get impressions from folks.
The Luxman P-200 is a compact high quality, high power pure A class amplifier, pumping out 2 watts per channel into 8Ω. Parallel Push-Pull structure. Connects are a 2 input switchable system.
CD player’s output can be passed through the P-200’s output to another pre-amplifier. P-200 is equipped with both a stereo mini plug socket and a ¼” high quality headphone socket. Beautiful aluminum front panel same as LUXMAN high-end series.
I used 2 pair of Headphones to evaluate the P-200. A pair of highly customized Grado PS-1s, where I have replaced the stock cable with our Black Dragon Cable and improved the resonance dampening inside the driver chamber. The second pair was a stock pair of Ultimate Ears UE10. Since the Luxman had a mini plug I thought what the heck. I used a Cary Audio SACD 306Pro as the source. I always want the best source I can use in an evaluation. This way I can hear how a unit can handle bad recordings and can rule out the source as the bad link in a negative review.
The overall sound is very smooth and not edgy sounding like a lot of it's competition in the solid state market under $1500. I used a headphone amplifier I built for myself as a comparison as I know it's sound very well and it has become a good reference point. It uses the Forssell Technologies JFET-993 Discrete Opamp, as the back bone of the unit as well as it has a Internal Dac, but we will ignore the dac section for this review. The 2 units are equal in sound quality but offer 2 flavors of sound.
With the UE10 I always do a noise level test. These phones are very sensitive to power supply noise and the Luxman did a great job of hiding any hash in the background. I had to crank the volume control up to it's limits to really hear residual PS Noise. Not many desktop amps can ward this off. If you use another phone that push the sensitivity threshhold you should be in good shape with this amp. Good job Luxman!
With music now added to the mix the Luxman gave a great deal of detail and good separation of instruments. I found the sound a little softer on the edges than my amp but this was not a negative in anyway, just a signature the amp has which enables you to listen to the amp for hours without listening fatigue. There are days where I will do computer work for 6-8hrs at a time. My headphones are always on while I'm in front of the screen so listening fatigue is very crucial to me. No worries with the Luxman. It passed with flying colors. I usually use Jazz as my reference to sound quality with a new piece of gear. Track 7 on Patricia Barber's Companion CD is very dynamic and has a lot going on. It can push an amp over the edge sonically. There are times where the horn section can distort out an amp as well. Miss Barber's voice as a result of her distance from the mic can sometimes add some high pitched ssssssssssssssssssss. Some amps handle this ok and some don't. On all accounts the Luxman did a wonderful job of passing the sound cleanly as possible to the phones. The Grado is a smoother sounding phone than the UE10, but there were never any times with the P-200 that I went "eeeech!!!" My amp had a little more low end or weigh to the sound but the Luxman low end was a little cleaner and crisper. It did a great job of controlling the bass. All and all I really like the amp and would recommend it to anyone. I am not a dealer for Luxman so my review is in no way biased. But who knows in the future I might be
Thank you Philip for letting us get the chance to hear this baby and I can't wait to here the big bother in the future.
