Shazam777
- Jul 21, 2011
Let me get this out of the way. I'm stupid. There it's done. If I sound like I don't have any knowledge on something or if I sound like an idiot, then you'll know why...cause I told you so. I'm legitimately not trying to troll or sound stupid on purpose. When it comes to audio, after all I've tried to cram into my brain, I still get dumbfounded time and time again.
Also, if this topic is in the wrong area, I apologize, and if it can be moved, feel free to do so.
Here's my current situation:
I just upgraded my computer, after having to, due to a power surge. Lost my mobo, gpu, cpu, and memory. My new rig runs phenomenal(it better after nearly $1000 worth of freaking upgrades) but I want to do away with on board sound. When I plug in my AKG Q701's they sound really low and weak even at max volume. So I did some looking on sound cards with built-in headphone amps in them and came across these two that seem to fit my needs(what do I know though..):
Asus Xonar Essence STX: http://www.newegg.com/Product/Product.aspx?Item=N82E16829132010
and
HT Omega Claro Halo: http://www.newegg.com/Product/Product.aspx?Item=N82E16829271004
So of course I read on both, cause I can never make up my mind and heard that both cards can amp higher impedence cans better than low(Q701's are only 62ohm) which I thought was weird(this is what I read, not what I said). Others say they'll be fine. Yet still others say a Desktop Amp/dac combo is the better route. Which I would connect through the Mobo's optical out, I'm assuming. As far as that is concerned, I wouldn't know which to get or where to get it when it comes to amps or dacs.
Now what would be the better route? I mostly will be gaming as well as talking through Skype/vent/etc during competitive/co-op games with friends(LoL, BF3, Diablo 3 etc.) I would also like whatever setup to be good for music and movies if I choose to listen/watch them. I'd say 80/20 ratio
Should I stick with the STX or Claro Halo?
Opt for a cheaper sound card such as:
Asus Xonar DX http://www.newegg.com/Product/Product.aspx?Item=N82E16829132006&Tpk=asus%20xonar%20dx
and then pair it with an amp/dac?
Or shoot for a good Amp/dac combo through optical out(which I assume is where it would be plugged in)
...or another option completely. Thanks in advance for any info.
and
