There is an update for the Creative X7 Control Panel
http://support.creative.com/downloads/download.aspx?nDownloadId=13394
I will give that a shot. Thanks
I first uninstalled both audio drivers. Then downloaded the newest software and installed it. I still have the original problem. So, then I decided to reboot to see if that would help and the two drivers I uninstalled automatically re-installed themselves at reboot.
The X7 program is loaded on my computer but I get the same error message: "Sound Blaster X7 cannot be detected. Ensure the device is connected to the computer, and it is powered on."
It is indeed connected to the computer but the X7 program will not open. Anybody ever have this problem?
I don't, unfortunately, but I do own the K7xx and note that these 'phones have a +3db in the bass region by design, compared to the K701 or the like, so I wouldn't think eq settings are interchangeable.
Hi All,
I finally found out that my antivirus, NOD32, was blocking the install. So, I uninstalled NOD32, then successfully installed the X7 software, and then reinstalled NOD32. Was a journey, but I was persistent as the reviewer of the X7 urged.
I am really enjoying the X7 now.
Hello. I just got the astro a50 xbox one edition for 219 or so from the Microsoft store.
Then I ordered the x7 from overstock for 359 dollars. It was supposed to be the limited edition but turned out to be the black one.
My question is should I return one of these two purchases?
My aim is high accuracy positional sound in FPS.
The headphone I would pair with the x70 is Phillips x1 or Sennh hd 650.
Would the scout mode match/beat the Astro Dolby surround?
Could I use the devices together? Synergy?
Thanks in advance. And have a blessed day.
