BigJoe
- Feb 17, 2015
Would anyone know how the X7 compares to the Dac Magic Plus? Roughly the same or is one noticeably superior for general all around music/TV/movies/gaming use?
I still have no idea how to enable playback through ASIO for this. I got some luck with ASIO4All but X7 is supposed to have their own driver. Unless USB Direct is asio playback.
[EDIT] I got Foobar to recognize the driver but it refuses to play any files when ASIO is selected. Not sure why's the case.
hi,Sooooo... windows is currently set for 5.1 and my X7 is outputting to headphones.
It was set in stereo from the last time I messed with it. I changed the configuration to 5.1 and played a test tone from Right-Front and for a moment it played correctly through my headphones, but near the end of the audio clip the Sound Blaster X7 Control Panel set the output to speakers. I remembered what Paco said, so in the X7 Control Center I turned off SBX and set the X7 to output to Speakers, changed Windows configure to stereo, turned SBX on, changed Windows configure to 5.1, set the X7 to headphone output... Voila, now it's outputting surround through headphones correctly. it's weird. To anyone having issue with the X7 automatically switching to speaker outs, mess around with SBX and windows sound configurations for a bit.
hi,
Did i need to do this with PS4, or is just for windows gaming?
Doubt it, when Priority is set on PS4 to bitstream )Dolby) the console is constantly outputting 5.1
@Evshrug - I noticed that the X7 switches back to stereo when sampling rate is set above 96khz. When I set it on 192khz it switched from 5.1 to stereo and refused to switch back, until i toned down sampling rate from 192 to 96.
@Evshrug
Just some random things (that I'm also going to post in the MLE thread.)
1) Due to bandwidth limitations, the X7 ONLY accepts surround sound IF it is at or below 96kbs. This limitation also extends to optical, which can't carry a 5.1 signal above 96 kbs anyway.
2) The amp can power my ZMF Vibros perfectly. It sends ~800mw at 50 ohms, so I'm not surprised.
That's about all I got.
Were you on low or high gain, Paco? Also, still looking forward to the Blackwood/Vibro impressions.
Opa 827 just arrived. Placebo or not they do seem to give more body to the HD700. Jambi (Tool) now sounds as good as I remembered.
Which ones did you buy and where did you buy them? This might have been covered earlier but I can't seem to find the post.
Can I connect a PS4 to the soundblaster while a PC is connected and output both the PC and PS4s audio?
