monsterquake
- Jun 9, 2015
https://www.reddit.com/r/sony/comments/v3fkbb/xm5_anc_software_issue/Please refer me to the Reddit posts.
https://www.reddit.com/r/sony/comments/v2tz9n/wh1000xm5_weak_anc/
https://www.reddit.com/r/sony/comments/v28911/i_got_xm5_but_i_have_noticed_left_side_is_louder/
https://www.reddit.com/r/sony/comments/v0kou6/xm5_anc_is_horrible/
https://www.reddit.com/r/sony/comments/uwry40/first_flight_with_the_xm5s_frustrating_experience/
https://www.reddit.com/r/sony/comments/uvghvq/xm5_nosie_cancelling_weak_vs_xm3/
https://www.reddit.com/r/sony/comments/uw5rtz/is_it_me_or_xm5s_anc_sucks_or_maybe_defect/
https://www.reddit.com/r/SonyHeadphones/comments/uz6oyg/weak_noise_cancelling_on_xm5/
https://www.reddit.com/r/SonyHeadphones/comments/v3idjb/wh1000xm5_loud_outside_noise_clipping_issue/
https://www.reddit.com/r/HeadphoneAdvice/comments/v1pg49/return_xm5s_for_xm4s_or_bose_qc45/
The ANC is now automatic, so you don't have control over it. Sony designed it in a way that is slow to change the levels and uncomfortable in how it is handled. There are multiple times when you want a higher ANC, but you can't because the unit doesn't think so and you cannot override it. When you are moving between zones, as the headset is slow to change and also do it automatically, you will be faced with constant changes of the ANC, that at the same time are slow reacting to the environment making a shitshow using them because the audio is constantly fluctuatingPlease describe problems with adaptive anc?
Adaptive anc can't foresee the future, so yes, you will hear the difference in operation.
It can be observed when starting to speak.
I agree that adaptive anc should be an option in settings.
On the old xm you simply put the ANC on the desired max level and everything was constant and useful. With XM5 nope, you can't.
For example, I am on a room with a single fan. I turn on the headphones and the ANC works at low level because whatever. It muffles the fan, but it doesn't disappear. Then you clap 10 seconds, after that time you stop clapping. Then the ANC thinks "oh I need to turn the ANC to higher levels" and the fan noise completely disappear, but 10 seconds later after you stopped clapping, the ANC go back again to a stupid level where it's not blocking anymore what it can really do.
And you can't change that. You are tied to whatever the headphones want to do at any time without any way to override it.
The software is a disaster, and seeing that on previous models sony never ever acknowledge the problems they had, I don't have faith in them fixing this with a firmware update, so until they solve it I cannot recommend to anyone the headset nor it can be justified to spend +400 on a problematic product.
