Hubert481
How to reduce contact pressure on Sony WH-1000XM5?
I was unable to get used to the top of the head hotspot/pain or the ear cartilage pain from my ears sinking further into the cups.How to reduce contact pressure on Sony WH-1000XM5?
HelloHello M5 owners, thoughts on the colours of the new model - I've been debating on which one to get. Been reading about the black colour being a fingerprint magnet and smudges easy which are quite visible compare to previous generations of the 1000X series. Any truth to this versus the silver colour since there's a texture difference to the build? Thnx!
I wish I had the silver to compare. The black is really horrible at picking up greasy looking stains just from the natural oils of your fingers. I'm being fairly precious about touching them and they just look kind of awful after a few days of taking them on and off and using the touch gestures; it's especially noticeable if you're in a well-lit environment. It's significantly more of a magnet for finger oils than my (blue) XM4's.Hello M5 owners, thoughts on the colours of the new model - I've been debating on which one to get. Been reading about the black colour being a fingerprint magnet and smudges easy which are quite visible compare to previous generations of the 1000X series. Any truth to this versus the silver colour since there's a texture difference to the build? Thnx!
Baby wipes, I cleaned every single day xm4 and I do the same with xm5.I wish I had the silver to compare. The black is really horrible at picking up greasy looking stains just from the natural oils of your fingers. I'm being fairly precious about touching them and they just look kind of awful after a few days of taking them on and off and using the touch gestures; it's especially noticeable if you're in a well-lit environment. It's significantly more of a magnet for finger oils than my (blue) XM4's.
Someone did suggest using display cleaner spray and a microfiber cloth to clean them - which helps, but I'm skeptical that the soft matte finish will last very long if I do that all the time.
So yeah, I do find the finish a bit disappointing.
With a greasy hair and skin If you had them on 10h every single day; you'd probably would see it differently.30 hours per year for cleaning a headphone? - wasted time
To summarize "everything is bad"Sony have to take full responsibility for their own own-goals.
Perhaps it is the use of recycled plastics that made them look so grubby?
Perhaps their obsession about battery life has lead to the much poorer ANC?
Anyway, I am looking forward to getting my money back for my returned XM5 and spending it on more gear that I don't need!
Don't take it seriously or just ignore it.I had and have almost all WH and WF and in terms of ANC, I only see improvements with the XM5 now. I am so confused what I ready here from some users.
