nc8000
As does my 16 month old unit so no redesignIt does click
That they do. No squish necessary, just s gentle push and rotate to fit them.You can just tell those tips will push into the ears better than the stock ones.
Have not had the time. I love babies! I also love my second priority. Sound. In due course.Going to have a serious analysis tonight since I bought them a few days ago. Haven't had the chance to insert them into my body yet.
They're aftermarket foam tips. I got mine from AE but Amazon has them now too.@assassin10000 , where did you get your Air Pod Pro tips? I assumed they were OEM, but Apple doesn't make black replacement tips.
To click or not to click - that apparently is the question Not sure if my old ones click sufficiently, but they still do sound very good with the Spinfit cp360 (although the b&o EX sounds quite a bit better - to my ears)Mine clicks too, but the click is subtle, so some people may not notice it
OK, now that’s cool! Can you print an IEM case?Ive just designed and 3d printed out a tip storage box...
You can print out anything if you good at 3d designing but Im not much good at it, so I mainly nick other peoples designs from Thingiverse web site.OK, now that’s cool! Can you print an IEM case?
I noticed since the first day that charging the case with the tws inside makes them hot, and overheating is not a good thing if you care about battery life. I charge the case when the xm4 are outside, I don't know if it helped but after 15 months I can still get over 4 hours with anc and ldac on.What codec do you use? I had 4-5 hours at first on LDAC. Now 2 if I am lucky I'll try to switch to SBC for a test though.
