Sorry to not be more clear but obviously I was referring to it's direct competition and those within a similar price point, not those that are much cheaper and not flagships.It will always be a divisive topic cos of the price differential with the 1AM2. I'd give it a listen if you are able to. Many variable factors, including your IEMs. It was the same debate with respect to the OG 1Z/1A. So, it is important to see what makes sense for you.
Sony Walkman Thread: 2022 Successors to the WM1A & WM1Z
psikey
- Jul 15, 2008
Not same, as the tuning was different between the two last time. I think board components varied a bit too.It will always be a divisive topic cos of the price differential with the 1AM2. I'd give it a listen if you are able to. Many variable factors, including your IEMs. It was the same debate with respect to the OG 1Z/1A. So, it is important to see what makes sense for you.
This time it's only the supposed improvement a copper body gives over aluminium, and use of an internal Kimber cable to the headphone out and that's it apart from extra 128GB internal memory.
To my ears and IEM's there was negligeable if any noticeable difference other than cost placebo.
It has a completely new internal power supply. I watched a YouTube video of the two main designers showing all the differences/improvementsNot same, as the tuning was different between the two last time. I think board components varied a bit too.
psikey
- Jul 15, 2008
Its new compared to V1, but V2 A&Z are same circuit board and PSU supposedly. Only copper case and Kimber cable the audio path differences.It has a completely new internal power supply. I watched a YouTube video of the two main designers showing all the differences/improvements
Is there anyone on hear using the NW-WM1ZM2 European version that is satisfied?
psikey
- Jul 15, 2008
You could order the A or Z from Amazon UK, try and easily return if not happy. They had one of each in stock yesterday.Is there anyone on hear using the NW-WM1ZM2 European version that is satisfied?
As I mentioned I had the EU/UK crippled Z and sent back the following day with complaint to Sony. Now have Japanese import A and no regrets buying and saving money by not going for the Z.
EU/UK could just drive my 3 IEM's at the time but lot of money for a crippled device with no headroom and need over 100/120 for one of my easy to drive IEM's.
Z still in stock
https://www.amazon.co.uk/Sony-NW-WM...AuMDAifQ==&sprefix=sony+WM1ZM2+,aps,83&sr=8-3
As it's now a few years since Sony made the first version, I am guessing it will be the same before they make its successor.
Many of the other manufacturers seem to have a new model out every couple of years. Is the Sony NW-WM1ZM2 suited to take many updates over the next few years to keep up with the competition when they potentially have another flagship?
Many thanks
Many thanks
psikey
- Jul 15, 2008
Sony never update the OS other than security fixes. It will never go from Android 11 IMO but it's a reasonably new OS that should have at least 6 good years support for Apps (streaming) and of course work as a standard (own file) music player until battery dies.As it's now a few years since Sony made the first version, I am guessing it will be the same before they make its successor.
Many thanks
It's a positive for me that Sony seem to have a longer life cycle of 3-4 years, so you don't think your out of date too soon after your expensive purchase and tempted to 'update' each year.
I'm not aware of any other Android DAP that has the OS update though either once released.
Android 11 is supported until late 2023Sony never update the OS other than security fixes. It will never go from Android 11 IMO but it's a reasonably new OS that should have at least 6 good years support for Apps (streaming) and of course work as a standard (own file) music player until battery dies.
wow im so glad they fixed the screen wake up delay with the latest firmware update.. i always thought i had worst luck of getting a defective unit.
Fedsbackhand
Where did your get your import? Doesn't look like Amazon Japan will ship to the UK.
Doug2507
You can get one from e-earphone and ship through tenso etc. Just keep in mind duty on top of value and shipping.Where did your get your import? Doesn't look like Amazon Japan will ship to the UK.
psikey
- Jul 15, 2008
Amazon Japan. I think I found one that slipped through Sony's export block!Where did your get your import? Doesn't look like Amazon Japan will ship to the UK.
It was a reseller but fullfiled by Amazon and nearly £300 less than UK RRP inc. Duties/delivery etc. I class myself as very lucky!
psikey
- Jul 15, 2008
Android supported yes, but will still be app supported well beyond that for streaming apps which is all I care about app-wise.Android 11 is supported until late 2023
Fedsbackhand
Thanks. Hopefully another one will slip through... I'd prefer to avoid a shipping forwarder if possible
