MrWalkman
Hi, I have installed firmware WM1A/Z+(3.02).
How to get back on 3.02. Is available somewhere firmware WM1 Back to Stock, please?
Thanks.
You don't need WM1 Back to Stock, just install the stock firmware.
Does the FE firmware on the 1Z use a lot of battery life? It's not really an issue for me as I use the player at home.My music files are AIFF rips from CDs,I understand file formats are a whole other issue, subject,etc..I'm simply curious, battery levels seem to drop pretty rapidly after not much use.Thanks!
WM1A and WM1Z have almost the same hardware (except some capacitors, resistors, and wires), and I didn't notice battery issues on my WM1A.
You could try using your 1Z until the device can't turn on anymore, and then leave it charging with the Battery Care setting off. While it's charging, don't use it. This should help recalibrating the battery.
