Feb 15, 2025 at 1:13 PM Post #8,989 of 9,237
At what point do I toggle the hold switch? While installing? While booting? At some other time?
No, you toggle the switch to show the Wampy UI, so after installing it.
Feb 15, 2025 at 1:45 PM Post #8,991 of 9,237
FM get auto-disabled when the music starts playing on the playe
Added in v1.8.1
BT receiver is active, changing filters works, but Wampy still shows that the change is enqueued, probably because there's no playing event happening.
Wampy is unaware of BT, only standard music player is what counts.
I must admit I did not think to try to toggle the hold switch
Please check wampy/logs directory, there might be something. If there is anything, I need it.
Wampy v1.8.1
  • upgrade volume tables plotting library (with out of bounds bug)
  • stop fm radio if music starts playing
  • fix digital clock build
  • volume tables online editor at https://unknown321.github.io/wampy/
  • updated documentation
https://github.com/unknown321/wampy/releases
I'd also like to thank everyone who donated; email notifications were off, so I noticed them only two hours ago.
Feb 15, 2025 at 2:56 PM Post #8,992 of 9,237
Wampy v1.8.1
Nice job!
The online editor wasn't loading the table for some reason - I checked in the console, and there's this:
These are all the errors:
I'm on Google Chrome, but it does this on Edge though (I know, they're basically the same).
Feb 15, 2025 at 3:18 PM Post #8,994 of 9,237
Feb 15, 2025 at 5:01 PM Post #8,996 of 9,237
What exactly are “volume tables”
I was going to send you a documentation link (as usual), but this is a good question, because I had no answer for it. I've updated the docs; here are the changes to save you some time:
Code:
What are volume tables for? They are used by CXD3778GF chip, which is also known as S-Master HX™ amplifier. Basically
they tell amplifier to amplify volume at X by value Y. Volume table application changes sound significantly, making it
at least louder, you can literally hear it while switching from `_cew` table to regular one.
How do they differe from eq ?
Can't say for sure, because I don't know how eq works exactly. Here is my simple take: volume tables amplify all frequences, while eq modifies only selected frequencies.
how did you uncover them?
https://github.com/unknown321/wampy/blob/master/MAKING_OF_VOLUME_TABLES.md there you go, now it's time to read some docs.
Feb 15, 2025 at 5:31 PM Post #8,997 of 9,237
Code:
So one additional question and if it’s documented I apologize… but given walkman one’s four tuning profiles (neutral, warm, bright, wm1z) if we boot up Walkman one on a50 on the wm1z tuning, would that be identical to booting up stock firmware and selecting wm1z on wampy? And if we select another devices volume table in wampy on Walkman one, does the “starting point” tuning of Walkman one have an effect in the volume table changes?
Feb 15, 2025 at 5:42 PM Post #8,998 of 9,237
I think it would, but there is no confirmation. Tried to prove it by capturing audio from a50 on stock and w1 using REW via PC line in to compare it later, but it was a failed attempt - maybe I was doing something wrong, maybe linux sound system wasn't communicating with REW properly. I hope there will be someone with more sound measurement experience who can do it.
No, new volume table (wampy) overwrites old one (w1).
Feb 15, 2025 at 6:14 PM Post #8,999 of 9,237
Are the values supposed to be a floating point-type (will it even work on the device)? On the device-Wampy there are only integers.
The floating-point type values show up when I zoom in at like the 13th mouse wheel click. The grid will start showing sub-divisions right at this point.
Edit: even if integers show up, you can place the dots to a value that's not an integer - if you zoom in, you'll see it, as well as you'll see the points having slight differences between them visually.
