MrWalkman
My understanding is that both FW's were designed with the WM1A in mind
Hey, that's not correct - the modified firmware were not designed with the WM1A in mind.
Imagine WM1A and WM1Z both with stock firmware, something like this:
And this is how WM1A/WM1Z would both look like if both would have DMP-WM1 FEv2/Project Z:
Because that software part is now common, which makes up for about 90-95% of the difference between a stock 1A and a stock 1Z, it means that the only difference is now the different hardware parts.
I was thinking Project Z for the WM1Z, but wondering if that might be redundant or overkill, since it's a WM1Z I'll be adding it to, rather than a WM1A?
With a tuning mod, a WM1Z would still have different sounding bass/soundstage for example, and a WM1A would be more neutral sounding, without that wide extending soundstage of the WM1Z for example. However, with one of these two custom firmware, these main differences are gone, so Project Z on a WM1Z wouldn't sound 2x warm for example, when compared to a WM1A with Project Z.
This would be a good representation on how the custom firmware works on these players, in regards to the sound quality:
And this would be one for how tuning mods work:
All this comes down to what I've been saying lately - these custom firmware versions are not working like tuning mods.
Am probably going to use DMP WM1 FE v2 on my hardware-modded WM1A, but I'd love to hear anyone's thoughts on the DMP WM1 FE v2 vs Project Z
It would be best if you would manage to try them both and see what you like.
I have a Nayparm extreme modded WM1A and a stock WM1Z.
The WM1A is currently running DMP WM1 II FW (according to the 'unit information')
The WM1Z is running DMP WM1 (version 1 I assume, since it doesn't say 'II' like on the WM1A).
I think that Project Z would be a treat on the Nayparm hardware modded WM1A, but it also depends if you like warmer sound signatures or not.
As WM1Z has a little better hardware than a stock WM1A, you could maybe use it with DMP-WM1 FEv2. Ironically, this would make the 1A be the warmer player, but I would say that Project Z would surely benefit from your 1A's modded hardware.
My WM1Z running plus is just over 10 hours with 50+% are DSD or hi-res FLAC. Same as you with minimal screen usage but enable Battery Care. Are you only play with 16/44.1 FLAC? I just did a battery calibration, will see if there is any improvement.
When I did the test, I let it play some albums from the beginning of my card, which are mostly 16/44.1 FLACs.
