audionewbi
- Jan 24, 2010
I had a question regarding MQA capability of WM1A. Is there a way to enable full MQA decoding on WM1A?
I beat it is possible, Sony just didn't want to pay the extra decoding fee to MQA.
Once again thank you for the amazing FW, it is crazy how much I enjoy my 1A thanks to your FW. I like it as much as my HM1000, if not more!
MQA decoding does work beautifully on the 1A in Walkman mode. As Sony targeted this player for portable listening, the DAC doesn’t support MQA decoding as most probably this player was meant for the portable listening market.I had a question regarding MQA capability of WM1A. Is there a way to enable full MQA decoding on WM1A?
sorry, how to install DMP-WM1_FEv2 and DMP-WM1_FEv2_Ext_Tuning???
You did a stock revert and back to stock 3.02? If so then yes. Just install the new FEv2 and also don’t forget to install the FEv2 external tuning as well immediately after. Then you’re good to go.i had one of the very, very old FWs by mrwm
i installed stock 3.02 to get back on zero and did a restart
am i ready now to install the FE+ ?
i installed stock 3.02 , if this is what you mean in the bold part
i then restarted my wm1a.
am i good to go into the next phase ?
and if i want to try the plus , i just put the hold switch up and just press 8 seconds for a restart , right ?
Turn off player. Flip switch to up position. Then press and hold power button.ok , i did both installs , i think everything worked fine , i see the dmp fe classic description in the unit information
