audionewbi
- Jan 24, 2010
can you give me a size comparison with stuffs so that I can see the size clearly? It looks real tiny
Is ipod nano 7G okay?
Sure , that would be a good size comparison , can I get thickness as well?
What a difference a day makes, this little sucker is good!
Comparisons with your AK120, Calyx M and AK10?
I think the measures were mentioned earlier in the thread. Why not simply look them up at Sony.com? There is all you need.
thank you so much, its thicker than I expected but still small enough to be in my consideration
I had this in my pocket all day and I work in a constantly moving work environment and I can tell you it feels hardly there. It fits really good in hand. I wish they used the old walkman navigation button but this one is okay too once you get used to it.
What I miss is lack of FF and RW hard button on the side of the A15. No major problem in my view.
Right now I am enjoying it using Oroton EQ-8, not bad at all!
They should have kept this design, the D-pad was raised so I can feel the buttons through thin pants quite easily.
Its the NWZ-A820 I have one exactly like this, its only 4GB with no SD or Flac, but I have it lined out to a Fiio E6 amplifier.
The beauty of the E6 is its 80hr battery life and dual headphone out. I just wish it sounded as good as my PHA-1 which only lasts 10hrs amped.
kindly elaborate
AK120 and Calyx M are priced much higher and therefore unfair, comparsion with AK10 I would take the A15 any day over Ak10. I will put the Ak10 onsale once I can find the original casing. I do not even know why anyone would buy the Ak10? It does not even sound better than ipod nano 7G!
I like Calyx M and it is my best DAP, Ak120 is really neutral and that makes it what some might consider boring. A15 has a nice balance to sounding detail and with the clear Bass to sound nice and warm. It has a great battery life and a much better UI than Ak120.
Also when you pressed down you could search the artist, title and even year in 2 clicks.
None of this scrolling albums BS this new one has.
Its the NWZ-A820 I have one exactly like this, its only 4GB with no SD or Flac, but I have it lined out to a Fiio E7 amplifier.
The beauty of the E7 is its 80hr battery life and dual headphone out. I just wish it sounded as good as my PHA-1 which only lasts 10hrs amped.
I'll be giving the NWZ-A820 + Fiio E7 combo as a Christmas gift to one of my brothers I think.
