Kvud
Aka: Muhadi
- Apr 23, 2011
I'm waiting for the new firmware!
in Mexico they already came with steep discount, from $5,400 down to 4, 300
Yes, it's an european model but my X is an european model as well so I do not understand why this difference in bass and power between them.
With my MDR 1A I have to go up around 18-20 on my A15 to have a decent volume while the X sounds good at 16 with the same headphones...oh well, I will just try to get used to it and *ignore* the power of the X because the A does sound richer and I really like how open it sounds.
Guess I will have to let my brain adjust to the new sound signature of the A15.
there was never a rule saying that the numbers on 2 DAPs had to equate to the same loudness. in fact almost no 2 DAP output exactly the same maximum voltage or max power, so starting from there, if 30 is different, how would the rest be the same?
also the volume cap is a voltage limit. when you rise the volume you increase the voltage. what I mean to say is that unless you're using your headphone at vol 30 and it's not loud enough, the volume cap isn't your problem.
not saying there isn't a problem, or that the A15 is perfect, because it's not. but the euro volume cap has most likely nothing to do with it. Different
Oh well, I think this is why the battery life is so good on the A. Less volume means less power drainage so people at Sony sacrificed power for a great battery life.
You can pair it with a portable head amplifier and a LOD
True, this would be ideal for home listening but because I walk/travel a lot, a bigger sized player would be inconvenient for me as I'm mobile most of the time.
I will just stop listening to my X so my brain can get used to the new signature and that's it.
