Polar1
mmm try resetting it (factory defaults reset) and it shall not display it or at least display some thing like this --:--
I just did that, but it instead of --:-- the clock still shows up as before
After few days with my new A15 I must admit I'm very happy with my purchase.
I was looking for an upgrade from my iPod Classic and for me it was down to the Fiio x5 or the iBasso x90.
...then the a15 cames in...
I still think both x5 and x90 give better resolution and better amping, but the size factor, smoothless UI, and ClearAudio+ enhancement, wow, I just couldn't ignore this magic regardless the SQ bill....
So I thought - I'll get a nice little amp and pair it to the a15 - this will compensate the SQ and amp drawbacks against the originally planned iBasso x90... but half a minute before doing that - I tried the HO with my fun-go-out, probably cheapest earphones I like the most - the Vosonic GR07 BE, no external amp, guess what?
They sound g-r-e-a-t!
Highs, lows, vocals, separation, soundstage - nothing to complain about...
Even the volume level that I was so worried about from reading, you know what - it's just about enough...
So I tried to pair it with my C&C BH2, both with L5 & L16 (Sorry, agsin, no difference to my ears...), well, I got more volume that's for sure, main advantage was a bit fuller bass, felt like your getting it with much less effort from the amp, a bit improvrment on the soundstage section, and that's about it....
Till now, whenever I connected the C&C to my android phone the difference was HUGE to my ears, but with the a15.. clearly that's not the case....
Does it worth the extra bulk? Surprisingly I think it's not....
Would a better amp will? Well, I guess I won't have the answer until I'll try one, but one thing's for sure - I'm a lot less stressed out to find one....
Thanks guys,
G.
I haven't installed the firmware update yet, perhaps after the update the clock will have to be set again and this will solve the "problem".
By the way, in the Firmware update instructions page it mentions that the data in the built-in memory might be damaged or deleted by the update, does this apply to the data stored in the SD card as well?
2 there is a clock, and it's the first time I see somebody unhappy about the fact that there is one. I don't look at it to get time so I could do without, but not to the point of actually needing to have it go away. is it for prisoners in guantanamo so that they can't see time when they're in a box with no holes?
LOL x 3
I use the clock only in the gym. The irritating part is checking if it shows the right time before starting my exercise.
Just wondering which, if any, of the cheapie USB data/charging cables available on Amazon or eBay are compatible with this model. I would like to have a spare. Most list a huge number of Walkmans they are compatible with, but none specifically mention the A10 series. Thanks for any info.
Can anyone tell me if the A10 will happily read files tagged in iTunes? My entire music collection is ITunes based - mostly ALAC (standard and hi-res) with some MP3.
There is no way I am going to re-tag the whole lot (life is too short) so if I upgrade from my Ipod Video it will need to be a DAP that won't fall over and die at the sight of a barrel of Apples...
Basically, it's between the Sony, X3 and DX50 and the one which copes best with ITunes tags will be the one I go for.
Grateful for the benefit of your collective experience.
Cheers
I've read that the A10 series have the so called EU volume cap restriction, but according to the A-15 manual, you're just getting a "beep" sound when reaching the limit which you can just ignore and bypass..
What is really happening here?
Is there a restriction in the maximum volume or just a notification and thats all it is?
