SONY NW-ZX700
Feb 9, 2024 at 5:47 AM Post #2,521 of 2,751
I haven't had the need to use high gain yet even when using notoriously hard to drive IEMs like the Final E5000.
Feb 9, 2024 at 6:44 AM Post #2,522 of 2,751
I feel the need for high gain when:
DSD and DIRECT sound ON
PCM (everything else) and DSD Remastering ON
Otherwise no need, from volume perspective, and the majority of the time I listen at pretty low volumes
Feb 9, 2024 at 11:19 AM Post #2,524 of 2,751
Be aware that the US version of the Walkman has significantly less power compared to the JP version also in Low Gain. It’s not the same regardless of High Gain.
Did the latest firmware update to the US version impact the volume at all? Just wondering as I am considering buying one at the current sale price.
Feb 9, 2024 at 12:00 PM Post #2,525 of 2,751
I don’t know what you mean. There was no change to volume limit in any firmware versions in any region as far as I‘m aware.
For a comparison of power on Low Gain
US - 1.1mW
JP - 50mW
High gain (JP only) - 230mW
Feb 9, 2024 at 12:55 PM Post #2,526 of 2,751
US - 1.1mW
JP - 50mW
Thanks. I was just wondering if subjectively, the new firmware seemed to provide higher volume or gain. In any event, given those low power numbers for the US model, I'll pass or scoop up a JP model at some point.
Feb 9, 2024 at 1:23 PM Post #2,527 of 2,751
Has anyone encountered track skipping when plugging usb c into a pair of headphones that take usbc out?
Feb 9, 2024 at 2:39 PM Post #2,528 of 2,751
Was going to wait until my next trip to Japan, but it is currently on sale on Amazon for $600 so I bit the bullet. The volume cap won't bother me, I'll be using the IER-M7 on this thing anyway
Feb 9, 2024 at 2:50 PM Post #2,529 of 2,751
Feb 9, 2024 at 3:24 PM Post #2,530 of 2,751
it's 569 USD on rakuma via FJ
https://www.fromjapan.co.jp/japan/en/special/order/confirm/https://item.fril.jp/47374797b512182f68749a4baa17913a/19_1/
+ shipping and tax. shipping is around 4500 yen, tax depends on your location. Also there's weekly 5-10% off discounts
in case you don't like the US one :D
But do report back, I'm quite curious too.
Thanks, and yeah I've even seen it dip below the $500 range as well on Mercari. I have personal experience with both the JP and US models and they are indistinguishable to me. I mainly use IEM (FINAL, intime, and Sony), and the only headphones I do have, the MDR-900CST, a potato can power that thing.
Feb 9, 2024 at 3:52 PM Post #2,531 of 2,751
You'll find a JP model brand new on eBay or may be even from Amazon JP for almost the same price as in the US now.
The price has gone down significantly after the initial rush of the release.
Feb 9, 2024 at 11:38 PM Post #2,532 of 2,751
A follow up to my usb c output stuttering issue.
So 44.1 KHz flac / 16 bit and 24 bit have issues playing but 96 KHz flac and above (192 kHz) 16 bit or 24 bit have no issues. Would you all have any hypothesis?
Feb 9, 2024 at 11:49 PM Post #2,533 of 2,751
The yen went down. The price stayed the same (94.000¥ new). It’s crazy. I just came back from Japan and I felt like I was in Southeast Asia due to Yen’s devaluation. Family said it’s bad tho for them 😬
So in January 2023 I paid 3122 PLN/ $780. Now it would be 2500 PLN/ $620 for a new unit.
Crazy. Got the IER-M9 for 80,000¥ / $530
Got 60 kilo of osenbe on return for 25-30k yen 😆
Feb 10, 2024 at 2:33 AM Post #2,534 of 2,751
Does the headphone work normally with other devices? If it does, a reset to factory on the Sony is the next thing to try.
Also reset the headphone if there is an option for that. This is usually a generic first step for troubleshooting.
Your symptom does not match the normal problem, where a higher bit rate, requiring more power, has problems.
But your symptom is that the lower bit rate is the one with the problem.
Feb 10, 2024 at 2:58 AM Post #2,535 of 2,751
Yes it does; also on the Sony’s it works out of the headphone jacks 3.5 and 4.4 mm no problem in all formats; just when it comes to usb-c out.
Headphones work fine playing the files out of usb-c with my iPhone 15
