musingclouds
- May 27, 2011
a 1 TB MicroSD from SanDisk seems to be good
The freezer might be a good option as well, depending on the type of music you listen to!It depends. In another thread people were just talking about which micro sd brand to choose depending on what type of sound you like - bright, warm, detailed etc. Oh and don’t forget to put it in the fridge if yo want the best sound !
By extension, putting your head in the freezer to cool the sound conversion unit of your ears, will have a positive effect. Try in 5 minute increments, and see what is optimum for your ears. Highly recommend that you give this a try.It depends. In another thread people were just talking about which micro sd brand to choose depending on what type of sound you like - bright, warm, detailed etc. Oh and don’t forget to put it in the fridge if yo want the best sound !
Don't forget the effects of gravity.By extension, putting your head in the freezer to cool the sound conversion unit of your ears, will have a positive effect. Try in 5 minute increments, and see what is optimum for your ears. Highly recommend that you give this a try.
You mean microwave ? I like my music warm !The freezer might be a good option as well, depending on the type of music you listen to!![]()
You could but your micro SD card will melt! Is it worth losing all of your music? Only you can decide!You mean microwave ? I like my music warm !
OMGIt depends. In another thread people were just talking about which micro sd brand to choose depending on what type of sound you like - bright, warm, detailed etc. Oh and don’t forget to put it in the fridge if yo want the best sound !
Sensitive equipment like medical imaging equipment requires more lower air conditioning temperatures in order to obtain more accurate diagnosis.By extension, putting your head in the freezer to cool the sound conversion unit of your ears, will have a positive effect. Try in 5 minute increments, and see what is optimum for your ears. Highly recommend that you give this a try.
https://en.m.wikipedia.org/wiki/Johnson–Nyquist_noiseThermal noise is present in all electrical circuits, and in sensitive electronic equipment (such as radio receivers) can drown out weak signals, and can be the limiting factor on sensitivity of electrical measuring instruments. Thermal noise increases with temperature. Some sensitive electronic equipment such as radio telescope receivers are cooled to cryogenictemperatures to reduce thermal noise in their circuits.
It also was explained, several times, that the Data, before getting processed, is loaded into the Internal Memory (RAM) and then loaded into the Cache and then is decoded and then is send to the S-Master HX.It depends. In another thread people were just talking about which micro sd brand to choose depending on what type of sound you like - bright, warm, detailed etc. Oh and don’t forget to put it in the fridge if yo want the best sound !
Finally, someone who has brains.It also was explained, several times, that the Data, before getting processed, is loaded into the Internal Memory (RAM) and then loaded into the Cache and then is decoded and then is send to the S-Master HX.
So the time when the "data" turns into music happens long after the data have been read from the MicroSD card and so the card has no relevance.
0110101001010 always sounds the same, no matter how hot/cold your MicroSD card is.
