Yeah, that's called the placebo effect.
If the codec settings are the same, it shouldn't matter what device you're using, as it's the headphones DAC being responsible for reading th
Ah thank you! Thats awesome.. and a bit hard to understand why Sony would opt by default for a lesser quality LDAC bitrate on their audiophile DAP, and make the option fairly hidden to change it.
I've tested it again now, seems a little better but still m11 Plus comes out on top by a fair margin, so it's obvious to me it's not just the codec that plays a part.
It is my experience also that Bluetooth implementations sound different. There are different qualities of hardware and how they are implemented, so it should not be a surprise that they can sound different. Every engineering design/implementation has tradeoffs, so there are many variables that can affect the end result.
Previously, I had not paid a lot of attention to this area, and used what I had on hand, and wanted to carry around, which was a ZX507, and recently an NW-A105 with BT earphones (WF1000XM3, M&D MW08). I had noted that using the ZX300 BT, the sound was not as "alive", pace seemed slower, but as the ZX507/A105 were my preferred players, I did nor worry about it.
Recently, I had occasion to look into this more closely, with a much more resolving setup. Using BT LDAC sound quality preferred, from the various Sony DAPs, driving a HifiMan HM1000 Red (r2r)-> Sony ier-m9
- ZX300 - the sound was as I noted previously. OK, but not involving. Not bad, not great. I was never attracted to using BT earphones with the ZX300, when I tried it before, though back then, I did not have a good BT earphone.
- A105 - remembering that the A105 and ZX507 are more recent DAPs, with more recent and up to date BT implementation and reading that people had said the ZX507 BT sounded better, and both actually sharing the same firmware, I tried the A105 feeding the HM1000 over LDAC. The big difference was that this combination was more alive and immersive. I was pulled into listening, which the ZX300 could not do. So that firms up my choice, that I would use BT from either the A105 or the ZX507 to drive BT earphones, or something like the HM1000
- ZX507 - tried this very quickly, and noted that it had similar characteristics to the A105, and that I liked the sound from this better than from the ZX300.
So that's what I observed.
BT is a complex transmission system, just as complex as the other "systems" in a DAP, and it's components, and implementation can be done differently, with results that can be better, or worse. So, unfortunately, it is not possible to just treat it as "BT is BT", and they all sound the same. Wish it were that simple, as we could then eliminate a variable/cost from the equation.
But then, we already know that "everything matters" in a system. Why would Bluetooth be different/an exception?
