Scubadevils
- Nov 18, 2011
Welcome!
To answer your question on the XBA-N3, I would recommend getting an uncapped ZX507 to get the absolute best out of those IEM’s. They are noticeably better with more power. The N3’s are quite bassy, and with low powered devices the bass can sound loose and undefined, which muddies up the whole presentation IMO. Conversely, an uncapped ZX507 in high gain drives them beautifully
If you don’t intend to stream music, there would be some advantages to going with a WM1A instead, most notably the battery life. WM1A battery life is fantastic. You’d be looking at almost 3x longer life. The other big advantage is the ability to install custom firmware to alter the sound signature of the DAP. There’s a whole thread on headfi dedicated to the custom firmware. Worth checking out. You could also buy a WM1A from a local dealer, as it’s fairly simple to remove the volume cap. The WM1A also has an extra 50mW of power from the balanced port, which isn’t a huge difference really, but it would be handy to have that extra little bit of juice if you plan to drive full size cans.
Just my 2c
Thanks for the reply!
Yes I figured that would be the reply alright re the ZX507 capped and the XBA-N3. It would be so easy to just order the ZX507 from Amazon on Prime and have it in a couple of days without any concerns around warranty but not if it would restrict my planned next set of IEMs - although they are actually hard to get now, Accessory Jack are one of a very few I can find them... very tempting to just go for both from them as a result. I suppose also that while I'm not planning spending big bucks on IEMs right now, that could well change in the coming months.
Meant to say also, another reason I was leaning more towards the ZX507 is for portability - especially walking my dog - size and weight vs. the WM1A a consideration but maybe not massively. No local sources for the WM1A - Amazon UK did have some but now showing as unavailble, brings me back to Accessory Jack! Ireland has never been good for DAP stockists, currently one I know of in Dublin and they only carry Fiio and A&K. I actually used to import a number of brands to include Fiio a few years ago but a tiny market so I gave it up...
Thanks again, definitely helped me decide re capped/uncapped. And the WM1A still very tempting, looks such a beautiful machine!
