N3llS
- Dec 6, 2015
Anybody tried using the Sony music center app for android on the ZX507? Does it have direct access to the DAC? I find the UI to be superior than the music app of the ZX507.
No it will not work.
3.5mm jack on the ZX507 Walkman is designed for TRRS balanced mode.
The 3.5mm jack on the right of the ZX507 has two ground connection as shown in this picture (ZX2). It's different from your standard 3.5mm jack.Actually I'm using the unbalanced standard mini jack on the right.
It is the same as the recent WM1A too, they are the same ground, just different paths. I guess what is going on is that electricity conduct to the path of being most effective, and therefore the different ground paths also effect sound quality. However, it is essentially the same ground. It bothered me a while back with Zx2, but the improved separations and performances is very real and can be observedThe 3.5mm jack on the right of the ZX507 has two ground connection as shown in this picture (ZX2). It's different from your standard 3.5mm jack.
Ordered my Benks case from AliExpress last week. Was given a crazy long-lead UK delivery time. Case turned up this morning
Nice! Care to share any close-up pics of front and back? How do you like it?
Is there a way to adjust the screen-saver timeout? Seems to be about 4 secs which I find a bit short.
For sure. You can set the lock screen like you want to. I disabled it completely. In the security and localization sub menu of your settings so you can remove the lock screen completely or just change it like you want it to be.
If you just want to change the time the device takes to go to the locking screen, it's the the display menu.
My device is set in French so I can't give you the exact names of the menu items, sorry!
Thank-you, but are you talking about the Sony cassette-playing screen-saver? Is this controlled by Android Display settings? I think it's part of the Sony Player App and can only see on or off options.
I have already disabled the Android lock screen.
Thanks, but it's this (the cassette display) that I want to change the timing on. I can only see on and off setting in the app.No, the cassette display is the the Sony player app itself in the parameters of the app.
Sorry i should have made it clearer.
Is USB cap coming with the case?I also like how I get to keep my 507 blanking plugs safe at home.
