shootertwist
- Sep 6, 2010
Yes we have been commenting about it several times already in this thread
Found it: Dec. 7, 2019, atahanuz in post 1062, spells it out - no line out.
Can confirm it definitely works via LDACI think it does usb audio out digital not analog.
I will receive my unit soon. I will do the test.
I want to use it as source to feed my wm1z via usb or ldac which ever works.
Though i think u canot use it as usb dac or bluetooth dac either. Mean audio in only out
Damz87 - did you ever get the sony xba z5 and NW-ZX507 to ever work? I know from the Z5 thread you complained about the mid bass bloat which is concerning. Did you have a chance to run them via balanced kimber cable on high gain and if so what were the results? Can the mid bass bloat be remedied by NW-ZX507 sound processing or filters (not referring to EQ) or did the updated firmware have any effect? These are probably the two most compelling audio products I would like to purchase, it would be a real shame if there was no cohesion there.
Did someone had m11 from fiio and listening 507. I am wondering what are the differences in sound as i sold my m11 and now thinking to get this good dap from sony. I liked m11 but didn't liked it that it had a little brighter tonality and a little bit too much emphasis on mid and treble, and low end lacked a bit. Also sometimes it sounded too much analytical and lacked musicality to sound so needed to use more warmer musical sounding iems to compensate this. So as i newer had sony dap don't know what to expect but does 507 is more musical or analytical dap. How do you think?
What an info. Thanks. This is what i need from dap. Not try to be detail monster but also to have enough of all frequencies. And this systemwide dsp is amazing thing as my m11 had eq only with default player and even then it was a joke as it practically wasn't working. So it seems it is upgrade in few main directions from m11 . What about low end. ? Looks like it is not lacking there. But how about control? Don't you feel it is boomy or loose as i liked m11 that it had really good control in low end even it was somehow lacking in low end feel compared to treble.It sits somehow in the middle of musical and analytical imo - with a slight tendency to musical and warmth. I have heard the m11, too, and definitely prefered the Sony for that reason. Another good thing about the Sony is that you have a lot of possible DSP adjustments of the sound - systemwide! So you can generally make it sound even more as you like it!
I have both NW ZX507 (Japanese version) Sony XBA Z5(made in Japan) and run them via balanced kimber cable on high gain and Direct source on and they pair fantastic, it sounds like perfect match and I truly enjoy pure magic sound stage and very detailed sound and I am not audiophile and so I may not express technically correct but it is real.ThanksDamz87 - did you ever get the sony xba z5 and NW-ZX507 to ever work? I know from the Z5 thread you complained about the mid bass bloat which is concerning. Did you have a chance to run them via balanced kimber cable on high gain and if so what were the results? Can the mid bass bloat be remedied by NW-ZX507 sound processing or filters (not referring to EQ) or did the updated firmware have any effect? These are probably the two most compelling audio products I would like to purchase, it would be a real shame if there was no cohesion there.
Does the NW-ZX507 support TIDAL with full MQA decoding and offline TIDAL playlists? I'm desperately trying to find a DAP that does all of that but there's pros and cons on just about every DAP.
