ZX500/A100 Optimization and Tweak Guide.
All these can be reversible back to original settings without any issues.
Please restart your device after disabling the apps/services to take effect:
To restart: with screen turn on, hold the power button for a few sec, then tap on restart
Disabling of Android Battery Optimization:
This tweak can improve stability of streaming apps. It will prevent Android from stopping or slowing down processing time of the streaming app or music player app.
You can also disable battery optimization for all apps in your walkman if you want a more responsive feel
This tweak might cause your battery life to decrease or cause extra heat. It really depends on the app's cpu usage & network usage on the system.
more info:
https://www.theandroidsoul.com/doze-mode-android/
To disable:
1) Settings > Apps & Notifications > Advanced > Special App Access > Battery Optimization >
Select App and Tap on Don't Optimize
choice of:
A) only don't optimize the streaming apps & music player that you use
B) don't optimize for all apps
Tips to improve battery time:
1) Settings > Security & Location > Find My Device > OFF
2) Settings > Security & Location > Privacy > Location > OFF
3) Settings > Accounts > Automatically Sync Data > OFF
4) Settings > Security & Location > Location > Advanced > Scanning > Switch OFF Both WIFI and Bluetooth Scanning
5) Settings > Google > Tap on Top Right of Screen at Vertical Three Dots, Usage & Diagnostics > OFF
6) Settings > Google > On-Device Sharing > Turn OFF all listed
7) Settings > Apps & Notifications > Advanced > Special App Access > Usage Access:
Switch off for Digital Well Being, Google, Google Play Services, Google Play Store
8)Turn off NFC: Settings > Connected Devices > Connection Preferences > NFC > OFF
Tips to Improve DAP responsiveness:
1) Settings > Accessibility > Remove Animations > ON
2) Download Google Files from Play Store
Clean Junk Files once in a while(weekly or daily)
3) Use GPU Acceleration: Settings > System > Advanced > *Developer Options > Force GPU Rendering > ON
* = To enable Developer mode: Settings > System > About Device > Build Number (tap 10 times on it)
4) Limit Background Process: Settings > System Advanced > "Developer Options > Background Process Limit: No Background Processes or At Most 2 Processes
This setting depends on what you are using your DAP for. If it's dedicated to just playing offline music, then no background process. If you are using USB Audio Player Pro along with Tidal, then increase the limit accordingly to the number of apps running.
More info here:
https://android.stackexchange.com/q...des-or-risks-to-limiting-background-processes
Apps that can be disabled safely without affecting playback functionality or performance:
1) Settings > Apps & Notifications > See All Apps:
Calculator
Calendar
Chrome
Contacts
Digital Wellbeing
Drive
Google
Google Japanese Input
Google Pinyin Input
Google Play Movies & TV
Google Play Music
Google Text to Speech Engine
Maps
mora
Photos
Redundant System Apps to disable:
Touch the three vertical dots on top right of screen then tap on [Show System]
Disable these:
Blocked Numbers Storage
Calendar Storage
Contacts Storage
com.android.soundrecorder
Default Print Service
Google One Time Init
Google Partner Setup
Google Backup Transport
Market Feedback Agent
Print Service Recommendation Service
User Dictionary
Hidden deep inside ZX507 settings, you can adjust bluetooth connection quality:
Settings > Connected Devices > Connection Preferences > Bluetooth > Wireless Playback Quality >
LDAC Sound Quality Pref.
LDAC Connection Pref. (This is default)
Aptx HD
AptX
AAC
SBC Sound Quality Pref.
SBC Connection Pref.
