I'm curious, if one never uses the 3.5mm jack, is there a point of trying to reach the 200hr mark on 3.5mm?
If you don’t use the 3.5mm output, no need to spend the time burning it in.
You're sure ? I just got a PM from MrWalkman stating I can just install it, without stock revert...You need to go to stock first.
Just installed it successfully directly "on top of" ZX300/A+, just like @MrWalkman said.
Now I will dive into my music library to "discover" the new Project Z sound signature...
Which version?Yes, I have.
Why ?
I have to check...Which version?
Yes, I have.
Why ?
I still have the ZX300/A+ or ++ versions 1.1 installersThe ++ version seems to be preferred by others. I would like to try it once more with different regions. I wanted to keep all the custom firmwares and unfortunately, some of the earlier ones got deleted. I'd appreciate it if you can provide a link for that copy you have. TIA
I can do that next week when I returned home after my holiday...
