Signal2Noise
Those are your impressions.
Your conclusion should be which one do you prefer?
I think one can have more than one conclusion from one experiment.. That's looking from all angles ie. being objectively possible..^
Just got the ZX-300, pairing it with a IER-M9. I've ordered a separate 4.4mm cable for it (a MUC-S12SM1), but for now I'm running it off a random 3.5mm I had around. I don't dare to use the included cables with the M9 - they cost far too much for me to break (around 2-300 euros to replace)
I'm liking the player a lot. Main draw for me was the battery life - I was getting a bit sick of my smartphone needing constant recharges throughout the day as I listen quite a bit on it. I've already run 2 full days of listening through it - battery indicator is still at 2 bars (out of 3). Just a note - using BT absolutely decimates the battery life. Not surprising, and most people won't be using it for that anyway, but just a heads-up.
Sound quality, I honestly do not have the ears to discern between DAPS and amps. But I can say, that the lack of background hiss is excellent. I even tried it on a Polaris (which is notoriously hissy, ala Campfire Audio) and it didn't so much as hiss either. Other DAPS I've tried unfortunately can't say the same - the Fiio M11 hissed like a snake throughout with the Polaris.
Some other comments:
- This thing is -thick-. It's over two times as thick as my phone. If you like wearing skinny jeans, that might be a problem. Good for battery and component noise reduction, bad for slimness. OK with suit pants and chinos.
- Besides thickness, it's actually quite petite. Me likey.
- OS isn't Android. Good - no nonsense, just music. If I want to use apps, I'll use my phone.
- WM-PORT sucks. No other way to say it - the recessed port is a bit of a drawback too as it's ridiculously easy to scuff the area if you plug it in the wrong way. USB-C or go home IMO.
- Screen is tiny. Good if you're young, bad if you're old. You're not looking at it all day anyway, so I see that as an acceptable compromise as that means the battery will last longer. That being said, it's painfully obvious this panel was taken from the ZX100, as that one actually made use of the blank area. Oh, and did I say it doesn't use glass? THANK YOU.
- Every time you connect it to a PC, you will rebuild database. The first time takes absolutely ages; every subsequent time takes barely a minute. Not ideal, but hardly the initial dealbreaker I thought it would be.
- Playlist support is disgusting. No other way to say it - if I bring a M3U playlist over, I can't add to it without some gymnastics. What I have to do it; 1. Create M3U playlist and transfer to ZX300. 2. Make a copy in ZX300, delete the M3U playlist, keeping in mind to rename the duplicated playlist the same name as the old one. 3. Add to it. Worse, whenever I sync to my computer, it'll automatically create an actual M3U playlist, and you'll have to repeat 1-3 again.
- 90% battery saver is a godsend. All my old Sony devices had something similar, and I can never thank them more for it. For those who don't know, the amount of 'effort' to charge from 20-80% for Li-Ion/Li-Po batteries is the same as 80-100%.
- No volume knob - good and bad. Good in that accidentally volume is no longer a real problem, bad in that I like knobs.
- Buttons are nice, and the volume+ and play buttons have a tactile bump to them. Shame I can't feel it as I put a Dignis case on it. Speaking of that case, very nice but good golly I wish it was cheaper.
- Takes ages to charge. Out of the box, it took ~4 hours to charge. For a 1500mAh battery, I have no idea what kind of CC-CV curve they're going for. I suppose it's a good thing - means they're not burning out the battery.
Might seem like a negative review, but I actually like it a lot. I always like to emphasise the negatives, because if it means you can overlook them, the positives can speak for themselves.
If only they can fix up the playlists...……….
Pretty much every MMCX cable I've tested in an audio store fits in. Now, if the MUC-M12NB1 has bigger MMCX heads than the other ones, I'm SOL and out a hundred or so, but I'm fairly optimistic. Will update when I receive it.
If only Amazon US didn't use the travesty that is iParcel, I'd have received it by now...……………….
That's good to know. I was pretty afraid myself to try out my other MMCX cables to the M9. Thanks man. Hope it goes well.
Hi, have a look at this thread:How much do you want for it?
That's odd! I have had no problems with a F150, Ford Edge, or several BMWs and Audis. What car?Bluetooth is my biggest issue... it doesn’t see my car!
PM me, if I don’t find a solution. Like you, I’d rather it just be “great!” after a few more hours playback and maybe some settings troubleshooting.How much do you want for it?
It’s a 2013 Volkswagen Golf. It seems to see Smartphone Bluetooth devices (including the FiiO running Android). So, it’s like a cheaper version of your Audi.That's odd! I have had no problems with a F150, Ford Edge, or several BMWs and Audis. What car?
