hezi
- Mar 10, 2015
Thank you! very helpful. Great player... love it with my Xelento.If you create a MUSIC Folder and put your tracks in it (flac, MP3...), yes it will be recognized after the scan.
I haven’t noticed any hiss with CA Andromeda in either SE or balanced. Could the cable be faulty?Hi,
I recently bought a fostex balanced cable (https://smile.amazon.com/gp/product/B079997SSH/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1) to use with my Sony mdr-7520 and zx300. There is noticeable hiss when I use this balanced setup. If I use the stock single-ended cable with zx300, there is barely any hiss.
Has anyone noticed hiss from the balanced output of zx300? Does burn-in solve the problem? Or the problem is with the cable?
Thanks!
Never. I have two different balanced cables and the output from the balanced port is always perfect.
Shane D
What headphones do you use with this? Have tried sensitive headphones with the balanced output?
I use one cable with Sony MDR-Z7's and HiFiman HE4XX's. I use the other with my Meze 99 Classics.
Shane D
I don't see how adding a cable to a headphone that has a single connection will make it balanced?
Unless internals of the jack are 3.5 TRRS on the Fostex and the Sony is the same?
If your headphone supports 3.5 TRRS at the cups then thats good. I believe most use TRS, only time with 4 poles if the cable has a mic. I'm not well versed on your cans/lots of full size cans to know 100%I don't understand the theory behind it but both sony and lavricables sell balanced cable with a single connection.
(https://smile.amazon.com/dp/B01M59H...colid=MXBS8MT8UMYY&psc=0&ref_=lv_ov_lig_dp_it
http://www.lavricables.com/cables/reference-silver-sony-mdr-z1000-mdr-7520/). Sony mdr1am2 also has a single connection but comes with a stock balanced cable.
I thought 3.5 TRRS is a standard and manufactures just implement it.
Ya, pretty sure both sides would be using a common ground, thats how my shure 840 was before I rewired it. That would explain the hiss. Best not use that cable anymore, dont want to ground fault the zx300. Not sure if it has some internal protection against things like that, but, better safe than sorry.
