My cost so far:
- ZX300 from Amazon UK £473 (maybe a 6 week wait to get)
- Genuine Sony Leather case from Amazon Japan £59 (maybe a 5 week wait to get) (or just 10% of normal ZX300 UK Amazon price which I think is OK)
- 2nd hand Sony MUC-A12SB1 XBA 4.4mm balanced Sony Kimber cable with mmcx off the forums £118 (likely arrive within 1 week). For use with my SE846's
- 4.4mm to 2.5mm adapter to try my existing Fiio balanced cable £6 (likely arrive within two week)
- Sony-WM-PORT-To-Micro-USB-Adapter-WMP-NWM10 £10 (first bit to arrive, today). Hopefully can use this to connect ZX300 to my old Sony Z5 compact for Tidal streaming via UAPP
So £666 (number of the beast!!) which I'm well pleased with seeing as ZX300 alone now back at £600 on Amazon UK. I'm not bothering with a screen protector seeing as I'm having the flip case plus I already have a 128GB microSD I will be using initially.
My only questions now are:
- Has anyone seen confirmation that ZX300 works OK as external DAC to Android & iPhone with correct cables (I could use either to stream Tidal from). Assume no issue direct to a PC but surely must have a software driver to support high bitrate & DSD
- Would like to try some Wireless headphones via LDAC or AptxHD. The ones I'm seeing as recommendations are Sony X1000M2 or B&W PX and from a sound quality perspective most seem to suggest the B&W PX is better. I don't really need ANC so any better recommendation without ANC to use LDAC or AptxHD and sound nearly as good or better than my Shure SE846's.
- What remote to use for the ZX300.
I'd assume if ZX300 does work linked to a smartphone then for Tidal streaming I'd need to change track on the phone but volume on the ZX300
