Sonic Defender
Removed, pointless conversation. My apology.
I've only listened to my zx2 on SE, although lower on power compare to others, it does have one of the best SQ if paired with the right iEM, I'm keeping mine, it's one of the best sounding DAP with good build, Sony has put everything behind the designing of it at its time, a truly classic at its best.
Nope, if you are bypassing the source in terms of signal processing and sending all to the PHA3 anyway, it doesn't matter. That is unless for some reason the source device is technically flawed and in someway passing on corrupted/compromised data to the PHA3. I owned the PHA3 with a Sony DAP and I can't say I noticed any difference between using the Sony DAP as a source as compared with when I used say my phone as a source. As long as the digital out is uncompromised, it really shouldn't matter.Can someone chime in please. I will be testing a Sony PHA-3 this weekend. I currently own the ZX2, but I wanted to compare the two side by side. I will be using the PHA-3 with my Samsung S7 and the ZX2 alone. I've read on this forum people pairing the ZX2 with the PHA-3. What is the benefit of this? I thought that once you run a source to a DAC/AMP that the original source's DAC/AMP is bypassed. I'm a bit confused, does the source matter at all (in terms of audio quality) if you plan on running it thru another DAC/AMP ?
Fully agree!Thanks for your obsevations. They're useful, but i'd have to say, for someone that didn't try TRRS, with ZX2, it is trully remarkable ! It's definitely not a placebo effect, it's a very real difference & improvement. The ZX2, is another "beast" altogether, with TRRS.
Thats probably why Sony kept the android 4.2.2, it's the most stable android available, i've also kept mine, and infact I've also had a new screen and battery put in when I visited Japan in December, the screen was my problem, had it shoved in my backpack with lots of stuff during my regular trip to china, too much pressure on the screen, which cause the glue to separate from the main glass and display, whiles it was on repair, i might as well change the battery, had mine for about 2.5 yrs as well. Now it's like 99.9% new, virtual no scratch or marks on the unit.I personally think there aren't any equivalent DAPs to ZX2 in the market. I'm using it for almost 2,5 years, one was stolen in the process but I luckily found another one 2nd hand.
If you consider the battery life, build quality, no hissing WiFi unlike some competitor DAPs, wide and deep staging, stereo image and resolution etc.. there's still no other choice for me. I'm talking about the streaming DAPs of course. Otherwise the WM1A is the better sounding Sony DAP (which I also have), not to mention the "out of this world" WM1Z.
Sure, it's using an old Android version and it's pretty slow for today's standard but to me it's not a big deal as long as I can use the TIDAL app.
The only model I would consider is the İbasso DX200 but it doesn't have the battery life like the ZX2. All the other Android DAPs I've tested are either meh sounding or they have a hissing WiFi module, or software bugs.
But isn't the AK mentioned are priced alot higher than the ZX2
