proedros
What if there is no ZX3? ☺
well , you can always re-release ZX2 without that stupid volume cap then
![wink.gif](http://files.head-fi.org/images/smilies/wink.gif)
I'm still hoping they have plans for a ZX3, android kit kat is getting a bit long in the tooth haha.
.... I'm afraid that Sony is not planning on developing high-end DAPs anytime soon.![]()
What makes you think that?
I don't think the ZX2 is capable of using as an external USB DAC. Only the AK can i believe
The Sony BCR-NWH10 Docking Station works very well for connecting the ZX2 to either a DAC or Computer and allows charging at the same time. I'm using one at the moment as I type.
I also use an NWH10 cable, but prefer the dock.
Bit of a pain that I had to direct import both from Japan though. What is Sony playing at?
I rarely interact with the OS, only the player. Would the Sony OS change the interface with the player itself?
It would, but Walkman OS had always been the easiest and friendliest for devices. Beside, it was made for music and efficiency.......aka....no music deforming or degrading and not running background trash that drain away the battery life![]()
