windstreak20
- Jun 30, 2015
Hi guys, can anyone post a pic of the TRRS adapter that can be used in zx2? one with the straight plug and an angled one please? TIA
I use a KEF M500 at this point, never plan to use IEM, can't stand anything inside my ear. I know it will be underpowered as my Blackberry Leap is at full power all the time with the KEF, and I assume the Leap outputs similar power but I can't confirm this.
Well, I drive my Z7 with it....so if it means anything. Since someone would love to get a zx2. I will remind you of the following
1/ disable the sound enhencement app from the setting to get the purest sound quality from ZX2. Some Europe people is reporting that by doing this, the Euro Cap is removed
2/ do not use "Dynamic Normalizer" it sucks and ruin sound quality
3/ use TRRS whenever possible for the best sound quality in tonality and separation
Full review on Zx2
http://www.head-fi.org/products/sony-walkman-nw-zx2-128gb-mp3-player-hi-res/reviews/14323
Great in depth review!
It really matches my own (far shorter) experience with the ZX2, you managed to put it into words Kudos !
Full review on Zx2
Does anyone know how to get deleted android apps back on the device ? I have deleted everything that I didn't use in order to conserve battery . I need to reinstall Spotify which means I need to get to the Google play store. I see that Google play store is running under apps, but there is no app icon on my main screen to actually turn it on . How do I get the icons Back?
Go into settings and to Apps, then to All and you will be able to enable Google playstore from there.
