Well, i think someone with a mac could be of better help but may be one thing to try is to download es file explorer on zx2 and show hidden files under the music folder and delete any files generated by the mac os..
SONY NW-ZX2
- Thread starter leylandi
i need help....
1. content transfer is not working after el capitan update on mac....
2. i am trying to transfer files with drag and drop but something is wrong..... my database update is always stuck at %35... sometimes 70 folders some times 26 or something.....
i reset the zx2 but still sticking at 35%.... ( with both sd card and internal memory )
also now tidal does not see my sd card..
there is something wrong here
what can i do?
also since tidal doesnt read the sdcard, you can check if it is read on es file explorer or even through storage settings, may be the sdcard is corrupted and causes this attitude.. or try removing the card and updating only internal library
emrelights1973
- Aug 16, 2015
the computer reads the sd card so i can drag and drop the files...... but tidal does not see nor sd niether internal memory....
so strange... overtime it stucks at %35...
i reset the zx2 but all same.....
kms108
- Jan 27, 2012
Try to format the SD card on the PC, then on the ZX2.
gerelmx1986
i need help....
what can i do?
switch to windows dude, Mac is flawed
Wilderness
- May 28, 2015
i need help....
what can i do?
I had a lot of problems trying to sync my playlist and 109 Gigs of music with my ZX2 and my Mac. I found that Sony's Content Transfer app would transfer my playlist and music but only if I deleted my old playlist and all of my music from my ZX2 first. That would then take four hours to transfer.
So, I found the Export for iTunes app in the Mac's App Store, and lo and behold it works! I did have to delete my playlist and all of my music from my ZX2 one time, but then after that it syncs very fast each time from iTunes by using the Export for iTunes app. And it is very easy to use.
If that route does not work for you, you might try reformatting your card as others have suggested and then try the Export for iTunes app. To save yourself a lot of time, you might try deleting all of your music and playlist from your ZX2's card, reformatting your card, and then try to transfer a few songs on a short playlist with the Export for iTunes app. If that does not work, you may have a bad card. In that case, try deleting all of your music and playlist from your ZX2's internal storage and then try to transfer a short playlist with the Export for iTunes app; if that does not work, you may have some corrupted music files.
You mentioned Tidal. Do you own the files? Or are you just streaming? Perhaps this is the problem? I have not tried Tidal, and so I can't really help you with that. Have you tried looking at the FAQ page at Tidal's website, or contacting Tidal's support?
edwardsean
- Jul 7, 2006
Check our Dapper. Don't know what I'd do without it.
https://itunes.apple.com/us/app/dapper/id903223330?mt=12
emrelights1973
- Aug 16, 2015
the problem is not sd card related, it does the same thing with internal storage, when i check the files and open them with es file explorer the files are there....
so the problem seems to be music player..... is not updating!!! i am so confuse....
Wilderness
- May 28, 2015
I tried Dapper, but I could not figure out how to get it to work.
Wilderness
- May 28, 2015
Have you deleted all of your music and playlist from your ZX2? And then have you tried to transfer some music again?
I know it stinks to have to delete the music and playlist -- all that time wasted -- and then start over, but that is step one and two. Step three: see my post above.
cheznous
- Oct 22, 2010
OS is not flawed but a number of programs have not yet been updated to run with capitan.
The most widely reported is Microsoft Outlook (shock horror).
Would suggest you simply restore from your last back up the previous operating system and wait until
everything you currently run works with the updated OS.
This is why I run time machine most days.
If it aint broke perhaps best to leave sometimes.
I doubt that the problem would be the OS, since it is just normal drag and drop of files,
but my doubts are either generated files by the os that might hang the update or corrupt sdcard or corrupt media files ( which i doubt because i had corrupt songs my self but it updated successfully )
i would just delete everything under music folders, remove sdcard and start only with internal memory and see whether it will go smooth or not ..
cheznous
- Oct 22, 2010
Sure but one of the complaints was that the content transfer programme had stopped working following his MAC update.
That is what I was referring to.
emrelights1973
- Aug 16, 2015
i solve the problem...... the list was not updating due to a corrupt file, just stoping at annoying %35.
one i have identified the file all seems to be working ( except the content transfer program which i thing is related to el capitan OS )
still all process stops working due to a single file.... i copy the files one by one and open the zx2 and find the corrupt one.... it took me like 4-5 hours!!!
as far as i understand once the content app is not working and you are just copying files any corrupt one can stop the process....
the content app was sort of filtering i guess
thank you all for your inputs
gerelmx1986
hey how many hours did your zx-2 took for burn-in process to settle?
Total: 14 (members: 0, guests: 14)
