Buddhahacker
Something like these.
Yes. Exactly like these. Do you know where I can pick them up?
The line out is way too low voltage. My portable amps can't gain enough volume at low. Infact it also gives some problem to my desktop amp for my less sensitive headphone so I gave up on the lod
[CONTENTEMBED=/t/742609/sony-nw-zx2-hi-end-dap/7650#post_11909857 layout=inline]Quote:[/CONTENTEMBED]
what headphones this player plays well?
Did you get the WMPORT Line-out cable? Because, in your CDM review you were just using the Headphone Out, which is not LO.
I had posted several times on Head-fi about my frustration with not being able to update my playlist on my ZX2 from my Mac.
I am very happy to report that I have found an app that makes it possible to update the playlist on the ZX2 from iTunes while using a Mac. The app is Export for iTunes, and it is available in the App Store.
I tested it to make sure it really does work by adding 10 songs to my 1,400 song playlist in iTunes on my Mac, and then I ran the easy to use Export for iTunes app and it worked perfectly. Now I can quickly add songs to my ZX2 playlist whenever I want.
I find that having a playlist is essential for use while driving on my long commute and on road trips.
Ahhh. All is well, as I already loved the ZX2 sound. :bigsmile_face: I will need to get a 200 GB card soon, as my ZX2's internal drive is down to just 5 GB of available space.
I'm curious since the NW-ZX2 runs Android and is Wi-Fi enabled, is it possible to store audio files online and download them directly to the device? I don't believe that OneDrive supports downloading folders, but thought there might be some other online services/apps that might do the trick (if indeed the files would go into the music folder on the NW-ZX2).
This is good news. Does it support FLAC? Or just aac or mp3. Also does this solve external card issue with playlist?
Thanks
Pc
Yeah, the one point that bums me out about the ZX2. I really want to use my Pure II with it but it just doesn't seem very feasible...
So it's not really balanced as there are no minus signals so you don't get the double voltage swing, but you should get the darker background from eliminating the common ground and possible crosstalk
