Leviticus
- Dec 15, 2014
Does anyone know if I can play 352kHz/24bit tracks with the ZX2?
Thanks, I think I will give this a try. So I'm guessing that I put the media on the device first and then create the new library pointing it to the walkman's storage. Correct?
What is out that is 352/24?
Right. Then open up the MUSIC folder on the Walkman in your finder, and drag and drop all the files into your iTunes window. The files will stay where they are but you will see the thumbnails in iTunes and can edit the song and album titles, etc.
Next time you want to put music on the Walkman, just drag the files from your Finder onto the iTunes window and they will be copied onto the Walkman.
That's great! Thanks
Quick thing to note -- I ran into this and had a little trouble. If you ripped CDs using itunes or tagged untagged files using itunes and it was tagged with ID v2.4 .. It doesn't show up as album in Zx2. It is grouped under unknown. The way to resolve that is use Mp3tag and run it in wine/winebottler in mac. Other way i did was open it in poweramp on ZX2 .. click edit tags and resave it .. This reconverts back to ID v2.3.. Something to keep in mind .. Also album art if above certain size i think 1000X1000 doesn't show in ZX2..
Also if you have images in the music folder and named them cover.jpg or folder.jpg you can see them all together if you want using only the gallery app or ES file explorer. The standard Sony picture app will not show it. Why you need you ask. I have been able to add album art to some albums by long pressing on the blank album cover and pick the image from this folder .. Just something else to know ( It took me sometime to figure this )
Also only music placed in MUSIC folder will show up in the player for both internal and external cards
Man, this thing better sound great for all the trouble it seems to be for Mac users!
Hi everyone
I just recently purchased Westone W60's and mostly listening on my desktop pc through Creative titanium HD sound card, i also using them on my phone when i am traveling, but obviously it lack's a lot of punch compared to the sound card. My question is will the ZX-2 equal or surpass the SQ of my sound card ?
Thanks
