- Jun 8, 2009
If the z3 turns out to be a good player I plan on getting the pha3 amp to use with it. Right now I'm using the Fiji e18 dac/amp but want something more powerful.
Don't forget that the PHA3 is deskbound (or is that just the EU version, I get so confused with regional variances!!)If the z3 turns out to be a good player I plan on getting the pha3 amp to use with it. Right now I'm using the Fiji e18 dac/amp but want something more powerful.
As a separate point, whilst awaiting meeting up with OK-Guy, something I've just spotted that might indicate EU volume limiting - for anyone who does NOT have an EU ZX2, if the unit is in landscape mode, and you adjust the volume does the 'master' (top) volume bar stretch right across the window? - mine doesn't, only goes about 4/5 of the way across (the bottom two volume bars go right the way across, but the top bar falls a bit short)...
If this is the same on non-EU versions, then fair enough, but this looks to be either a limit, or a really odd decision by Sony not to have the volume bars lined up correctly.
...I suppose this is better explained with a picture - as below:
...Oops, realised that (by the clock on the image) it is 2am, I need to be up at 6... damnit for keeping me awake!!
I just purchase a Sony experia z3 to use as a player only. I know it can do much of what the zx2 can do but without the amp. What else does the zx2 have on the z3? I have spotify so I'm assuming I can do streaming.
Also, I used Sony bridge to bring my iTunes playlists over to z3, but it seemed to have converted my alac m4a files to something that takes up less space? What did it convert to?
the volume display panel appears to be slightly different on the Japanese ZX2 model, more noticeable in landscape mode, hth.
I suspect mine is a non eu but how do you determine that? Mine does the same thing.
I can confirm that the Australian stock with no cap, also has the same master volume range.
Well, PRF-NWH40 screen protector now on, but my absolute OCD is kicking in that there is a tiny bit of something sandwiched in between it and the screen, right next to the next track button on the below image...
...on the bright side though, was able to keep the hi res sticker
On a complete off topic, so looking forward to going to see Jenn Bostic on Wednesday![]()
